Ana içeriğe geç
Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement
Neye ihtiyacın var
  1. Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement, Battery: adım 1, 1 resimden 1.
    • First flip the device over so that the back side is facing upwards
  2. Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: adım 2, 1 resimden 1.
    • Push the two sliders toward the edge of the laptop.
    • Remove the battery.
  3. Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement, Display Assembly: adım 3, 1 resimden 1.
    • Open the lid.
  4. Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: adım 4, 3 resimden 1. Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: adım 4, 3 resimden 2. Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: adım 4, 3 resimden 3.
    • Remove the four screw covers in each of the four corners of the screen.
  5. Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: adım 5, 3 resimden 1. Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: adım 5, 3 resimden 2. Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: adım 5, 3 resimden 3.
    • Remove the 4 screws in each of the 4 corners.
  6. Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: adım 6, 3 resimden 1. Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: adım 6, 3 resimden 2. Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: adım 6, 3 resimden 3.
    • Take your prying tool and proceed to pry the screen cover off and set to the side.
  7. Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: adım 7, 1 resimden 1.
    • Disconnect the wire from the camera and the backside of the display assembly.
  8. Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: adım 8, 3 resimden 1. Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: adım 8, 3 resimden 2. Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: adım 8, 3 resimden 3.
    • Remove the 6 screws holding the display assembly and holding brackets together.
Sonuç
Jacob Volcke
665 İtibar
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 103
