Ana içeriğe geç
Toshiba Satellite P855-S5102 Hard Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite P855-S5102 Hard Drive Replacement, Battery: adım 1, 2 resimden 1. Toshiba Satellite P855-S5102 Hard Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Push the locking tabs away from each other.
  2. Toshiba Satellite P855-S5102 Hard Drive Replacement: adım 2, 2 resimden 1. Toshiba Satellite P855-S5102 Hard Drive Replacement: adım 2, 2 resimden 2.
    • Pull up on the battery to remove.
  3. Toshiba Satellite P855-S5102 Hard Drive Replacement, RAM: adım 3, 2 resimden 1. Toshiba Satellite P855-S5102 Hard Drive Replacement, RAM: adım 3, 2 resimden 2.
    • Remove the 3mm Phillips #0 screw from the cover.
  4. Toshiba Satellite P855-S5102 Hard Drive Replacement: adım 4, 3 resimden 1. Toshiba Satellite P855-S5102 Hard Drive Replacement: adım 4, 3 resimden 2. Toshiba Satellite P855-S5102 Hard Drive Replacement: adım 4, 3 resimden 3.
    • Use a plastic opening tool to lift up the cover and remove by hand.
  5. Toshiba Satellite P855-S5102 Hard Drive Replacement: adım 5, 3 resimden 1. Toshiba Satellite P855-S5102 Hard Drive Replacement: adım 5, 3 resimden 2. Toshiba Satellite P855-S5102 Hard Drive Replacement: adım 5, 3 resimden 3.
    • Two clips secure the RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
    • When released, the RAM module will pop up at a slight angle.
Lift the RAM module to an angle of about 30 degrees and slide it out.
  6. Toshiba Satellite P855-S5102 Hard Drive Replacement, Hard Drive: adım 6, 1 resimden 1.
    • Remove the three 3mm Phillips #0 screws from the hard drive.
    • Remove the hard drive.
Sonuç
Benson Smith
351 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S20-G3, Passmore Spring 2018 USF Tampa, Team S20-G3, Passmore Spring 2018 üyesi
USFT-PASSMORE-S18S20G3
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 11
Her zaman: 739
