Ana içeriğe geç
Toshiba Satellite P855-S5102 Laptop Screen Replacement
Neye ihtiyacın var
  1. Toshiba Satellite P855-S5102 Laptop Screen Replacement, Laptop Screen: adım 1, 2 resimden 1. Toshiba Satellite P855-S5102 Laptop Screen Replacement, Laptop Screen: adım 1, 2 resimden 2.
    • Remove the two F3 screws on the bottom part of the screen.
  2. Toshiba Satellite P855-S5102 Laptop Screen Replacement: adım 2, 2 resimden 1. Toshiba Satellite P855-S5102 Laptop Screen Replacement: adım 2, 2 resimden 2.
    • Using a plastic opening tool, carefully pry open the border of the screen away from the screen until the border is completely off.
  3. Toshiba Satellite P855-S5102 Laptop Screen Replacement: adım 3, 3 resimden 1. Toshiba Satellite P855-S5102 Laptop Screen Replacement: adım 3, 3 resimden 2. Toshiba Satellite P855-S5102 Laptop Screen Replacement: adım 3, 3 resimden 3.
    • Using the Phillips 001, carefully remove each F3 screw on each corner of the screen.
  4. Toshiba Satellite P855-S5102 Laptop Screen Replacement: adım 4, 3 resimden 1. Toshiba Satellite P855-S5102 Laptop Screen Replacement: adım 4, 3 resimden 2. Toshiba Satellite P855-S5102 Laptop Screen Replacement: adım 4, 3 resimden 3.
    • Using the Phillips 012, remove the three F2 screws on each side of the screen.
  5. Toshiba Satellite P855-S5102 Laptop Screen Replacement: adım 5, 2 resimden 1. Toshiba Satellite P855-S5102 Laptop Screen Replacement: adım 5, 2 resimden 2.
    • Carefully lift up the screen for an easier removal of the webcam. Then gently remove the connector by sliding it out of the webcam.
  6. Toshiba Satellite P855-S5102 Laptop Screen Replacement: adım 6, 2 resimden 1. Toshiba Satellite P855-S5102 Laptop Screen Replacement: adım 6, 2 resimden 2.
    • Remove the tape holding the sliding connector and gently pull it out.
Sonuç
Rodrigo
133 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S20-G3, Passmore Spring 2018 USF Tampa, Team S20-G3, Passmore Spring 2018 üyesi
USFT-PASSMORE-S18S20G3
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 258
