Ana içeriğe geç
Toshiba Satellite P855-S5312 Fan Replacement
Neye ihtiyacın var
  1. Toshiba Satellite P855-S5312 Fan Replacement, Battery: adım 1, 3 resimden 1. Toshiba Satellite P855-S5312 Fan Replacement, Battery: adım 1, 3 resimden 2. Toshiba Satellite P855-S5312 Fan Replacement, Battery: adım 1, 3 resimden 3.
    • Turn laptop upside down with the spine facing towards you and locate the two tabs on the top of the back panel.
    • Move the sliders to the left and right to release the tabs holding the battery in.
    • While the tabs are pushed outwards, remove the battery from the device.
  2. Toshiba Satellite P855-S5312 Fan Replacement, Keyboard: adım 2, 3 resimden 1. Toshiba Satellite P855-S5312 Fan Replacement, Keyboard: adım 2, 3 resimden 2. Toshiba Satellite P855-S5312 Fan Replacement, Keyboard: adım 2, 3 resimden 3.
    • Using plastic spudger to pry up the edges of the keyboard and lift it towards the screen.
    • Unplug the ZIF connector ribbon using the plastic spudger by gently prying the edges of the plug.
    • Remove the keyboard from the device.
  3. Toshiba Satellite P855-S5312 Fan Replacement, Fan: adım 3, 3 resimden 1. Toshiba Satellite P855-S5312 Fan Replacement, Fan: adım 3, 3 resimden 2. Toshiba Satellite P855-S5312 Fan Replacement, Fan: adım 3, 3 resimden 3.
    • Unscrew the one 1.5mm screw using a Philips #0 screwdriver holding the L shape panel.
    • Pry up the panel to gain access to hidden screws.
  4. Toshiba Satellite P855-S5312 Fan Replacement: adım 4, 2 resimden 1. Toshiba Satellite P855-S5312 Fan Replacement: adım 4, 2 resimden 2.
    • Remove the fourteen (14) screws using a Philips #0 screwdriver for the 1.5mm screws on the underside of casing.
  5. Toshiba Satellite P855-S5312 Fan Replacement: adım 5, 3 resimden 1. Toshiba Satellite P855-S5312 Fan Replacement: adım 5, 3 resimden 2. Toshiba Satellite P855-S5312 Fan Replacement: adım 5, 3 resimden 3.
    • Unscrew the nine 1.5mm screws using a Philips #0 screwdriver under the keyboard with the F6 printed next to them.
    • Unplug the three no-fuss ribbon cable connector cables by gently pulling on them away from you towards the keyboard.
  6. Toshiba Satellite P855-S5312 Fan Replacement: adım 6, 2 resimden 1. Toshiba Satellite P855-S5312 Fan Replacement: adım 6, 2 resimden 2.
    • Pry apart the casing with the plastic opening tool.
    • Removing the cover under keyboard.
  7. Toshiba Satellite P855-S5312 Fan Replacement: adım 7, 3 resimden 1. Toshiba Satellite P855-S5312 Fan Replacement: adım 7, 3 resimden 2. Toshiba Satellite P855-S5312 Fan Replacement: adım 7, 3 resimden 3.
    • Unplug the single no-fuss cable connector using the plastic opening tool pushing the edges towards the fan.
    • Unscrew the two 1.5mm screws using a Philips #0 screwdriver by the head mounting holding down the fan.
    • Pull the fan up and remove it from the device.
Sonuç
Dalton
215 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S10-G2, Thompson Fall 2017 USF Tampa, Team S10-G2, Thompson Fall 2017 üyesi
USFT-THOMPSON-F17S10G2
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 8
Her zaman: 616
