Ana içeriğe geç
Toshiba Satellite P855-S5312 Keyboard Replacement
Neye ihtiyacın var
  1. Toshiba Satellite P855-S5312 Keyboard Replacement, Battery: adım 1, 3 resimden 1. Toshiba Satellite P855-S5312 Keyboard Replacement, Battery: adım 1, 3 resimden 2. Toshiba Satellite P855-S5312 Keyboard Replacement, Battery: adım 1, 3 resimden 3.
    • Turn laptop upside down with the spine facing towards you and locate the two tabs on the top of the back panel.
    • Move the sliders to the left and right to release the tabs holding the battery in.
    • While the tabs are pushed outwards, remove the battery from the device.
  2. Toshiba Satellite P855-S5312 Keyboard Replacement, Keyboard: adım 2, 3 resimden 1. Toshiba Satellite P855-S5312 Keyboard Replacement, Keyboard: adım 2, 3 resimden 2. Toshiba Satellite P855-S5312 Keyboard Replacement, Keyboard: adım 2, 3 resimden 3.
    • Using plastic spudger to pry up the edges of the keyboard and lift it towards the screen.
    • Unplug the ZIF connector ribbon using the plastic spudger by gently prying the edges of the plug.
    • Remove the keyboard from the device.
Sonuç
To reassemble your device, plug the ribbon into circuit board and snap the replacement keyboard in place.
Dalton
215 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S10-G2, Thompson Fall 2017 USF Tampa, Team S10-G2, Thompson Fall 2017 üyesi
USFT-THOMPSON-F17S10G2
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 1,253
