Ana içeriğe geç
Toshiba Satellite P855-S5312 Screen Replacement
Neye ihtiyacın var
  1. Toshiba Satellite P855-S5312 Screen Replacement, Fan: adım 1, 3 resimden 1. Toshiba Satellite P855-S5312 Screen Replacement, Fan: adım 1, 3 resimden 2. Toshiba Satellite P855-S5312 Screen Replacement, Fan: adım 1, 3 resimden 3.
    • Unscrew the one 1.5mm screw using a Philips #0 screwdriver holding the L shape panel.
    • Pry up the panel to gain access to hidden screws.
  2. Toshiba Satellite P855-S5312 Screen Replacement: adım 2, 2 resimden 1. Toshiba Satellite P855-S5312 Screen Replacement: adım 2, 2 resimden 2.
    • Remove the fourteen (14) screws using a Philips #0 screwdriver for the 1.5mm screws on the underside of casing.
  3. Toshiba Satellite P855-S5312 Screen Replacement: adım 3, 3 resimden 1. Toshiba Satellite P855-S5312 Screen Replacement: adım 3, 3 resimden 2. Toshiba Satellite P855-S5312 Screen Replacement: adım 3, 3 resimden 3.
    • Unscrew the nine 1.5mm screws using a Philips #0 screwdriver under the keyboard with the F6 printed next to them.
    • Unplug the three no-fuss ribbon cable connector cables by gently pulling on them away from you towards the keyboard.
  4. Toshiba Satellite P855-S5312 Screen Replacement: adım 4, 2 resimden 1. Toshiba Satellite P855-S5312 Screen Replacement: adım 4, 2 resimden 2.
    • Pry apart the casing with the plastic opening tool.
    • Removing the cover under keyboard.
  5. Toshiba Satellite P855-S5312 Screen Replacement: adım 5, 3 resimden 1. Toshiba Satellite P855-S5312 Screen Replacement: adım 5, 3 resimden 2. Toshiba Satellite P855-S5312 Screen Replacement: adım 5, 3 resimden 3.
    • Unplug the single no-fuss cable connector using the plastic opening tool pushing the edges towards the fan.
    • Unscrew the two 1.5mm screws using a Philips #0 screwdriver by the head mounting holding down the fan.
    • Pull the fan up and remove it from the device.
  6. Toshiba Satellite P855-S5312 Screen Replacement, Screen: adım 6, 3 resimden 1. Toshiba Satellite P855-S5312 Screen Replacement, Screen: adım 6, 3 resimden 2. Toshiba Satellite P855-S5312 Screen Replacement, Screen: adım 6, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Turn laptop upside down with the spine facing towards you and locate the microchip.
    • Remove the white and black sliding connector wires by prying upward with tweezers gently pulling the black and white wires upwards.
  7. Toshiba Satellite P855-S5312 Screen Replacement: adım 7, 2 resimden 1. Toshiba Satellite P855-S5312 Screen Replacement: adım 7, 2 resimden 2.
    • Unplug the single ZIF connector ribbon by gently pulling up.
    • Pull the white and black wires through from the underside of device.
  8. Toshiba Satellite P855-S5312 Screen Replacement: adım 8, 3 resimden 1. Toshiba Satellite P855-S5312 Screen Replacement: adım 8, 3 resimden 2. Toshiba Satellite P855-S5312 Screen Replacement: adım 8, 3 resimden 3.
    • Unscrew the four hinges mounting the 1.5mm screws on each side from casing using a Philips #0 screwdriver.
    • Remove entire screen assembly from casing.
  9. Toshiba Satellite P855-S5312 Screen Replacement: adım 9, 3 resimden 1. Toshiba Satellite P855-S5312 Screen Replacement: adım 9, 3 resimden 2. Toshiba Satellite P855-S5312 Screen Replacement: adım 9, 3 resimden 3.
    • Locate the two black sticker covers on the bottom of both sides of the monitor
    • Using a pair of tweezers, carefully remove black stickers concealing two screws
  10. Toshiba Satellite P855-S5312 Screen Replacement: adım 10, 3 resimden 1. Toshiba Satellite P855-S5312 Screen Replacement: adım 10, 3 resimden 2. Toshiba Satellite P855-S5312 Screen Replacement: adım 10, 3 resimden 3.
    • Using a prying tool, carefully pry along the edges of the screen cover
  11. Toshiba Satellite P855-S5312 Screen Replacement: adım 11, 2 resimden 1. Toshiba Satellite P855-S5312 Screen Replacement: adım 11, 2 resimden 2.
    • Unscrew the two 1.5mm screws at the bottom of monitor using a Philips #0 screwdriver.
  12. Toshiba Satellite P855-S5312 Screen Replacement: adım 12, 3 resimden 1. Toshiba Satellite P855-S5312 Screen Replacement: adım 12, 3 resimden 2. Toshiba Satellite P855-S5312 Screen Replacement: adım 12, 3 resimden 3.
    • With all the edges of the screen cover pried up, carefully remove the screen cover.
  13. Toshiba Satellite P855-S5312 Screen Replacement: adım 13, 3 resimden 1. Toshiba Satellite P855-S5312 Screen Replacement: adım 13, 3 resimden 2. Toshiba Satellite P855-S5312 Screen Replacement: adım 13, 3 resimden 3.
    • Using the Philips #0 screwdriver, remove the four 1.5mm screws at the corners of the screen.
  14. Toshiba Satellite P855-S5312 Screen Replacement: adım 14, 3 resimden 1. Toshiba Satellite P855-S5312 Screen Replacement: adım 14, 3 resimden 2. Toshiba Satellite P855-S5312 Screen Replacement: adım 14, 3 resimden 3.
    • At the top of the screen, using the tweezers, remove the ZIF ribbon connector by gently pushing it up.
  15. Toshiba Satellite P855-S5312 Screen Replacement: adım 15, 2 resimden 1. Toshiba Satellite P855-S5312 Screen Replacement: adım 15, 2 resimden 2.
    • Remove the screen from the device.
    • Make sure to be carful because the screen is very fragile.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bishop Clark
225 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S10-G2, Thompson Fall 2017 USF Tampa, Team S10-G2, Thompson Fall 2017 üyesi
USFT-THOMPSON-F17S10G2
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 5
Son 30 gün: 10
Her zaman: 795
