Ana içeriğe geç
Toshiba Satellite R15-S829 Hard Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite R15-S829 Hard Drive Replacement, Battery Replacement: adım 1, 1 resimden 1.
    • Unplug the charging cable from the laptop.
    • Turn off the laptop.
    • Turn the laptop over and locate the battery.
  2. Toshiba Satellite R15-S829 Hard Drive Replacement: adım 2, 3 resimden 1. Toshiba Satellite R15-S829 Hard Drive Replacement: adım 2, 3 resimden 2. Toshiba Satellite R15-S829 Hard Drive Replacement: adım 2, 3 resimden 3.
    • Push the small switch near the corner of the laptop to the unlocked position.
    • Push the bigger switch in the direction of the icon and pull the battery away from the laptop.
  3. Toshiba Satellite R15-S829 Hard Drive Replacement, Hard Drive Replacement: adım 3, 1 resimden 1.
    • First, begin by locating the spot of the cover of the hard drive located on the bottom of the laptop.
  4. Toshiba Satellite R15-S829 Hard Drive Replacement: adım 4, 1 resimden 1.
    • Remove the screw of the cover.
  5. Toshiba Satellite R15-S829 Hard Drive Replacement: adım 5, 2 resimden 1. Toshiba Satellite R15-S829 Hard Drive Replacement: adım 5, 2 resimden 2.
    • Locate the indent where the hard drive can be removed. Remove the cover.
  6. Toshiba Satellite R15-S829 Hard Drive Replacement: adım 6, 2 resimden 1. Toshiba Satellite R15-S829 Hard Drive Replacement: adım 6, 2 resimden 2.
    • Remove the hard drive using your hand.
  7. Toshiba Satellite R15-S829 Hard Drive Replacement: adım 7, 3 resimden 1. Toshiba Satellite R15-S829 Hard Drive Replacement: adım 7, 3 resimden 2. Toshiba Satellite R15-S829 Hard Drive Replacement: adım 7, 3 resimden 3.
    • Now remove the power ribbon from the hard drive.
  8. Toshiba Satellite R15-S829 Hard Drive Replacement: adım 8, 1 resimden 1.
    • Locate the screws on each side of the encasing of the hard drive.
  9. Toshiba Satellite R15-S829 Hard Drive Replacement: adım 9, 2 resimden 1. Toshiba Satellite R15-S829 Hard Drive Replacement: adım 9, 2 resimden 2.
    • Use your Phillips screwdriver to remove the screws and be careful not to lose the screws.
  10. Toshiba Satellite R15-S829 Hard Drive Replacement: adım 10, 1 resimden 1.
    • Remove the encasing from the hard drive.
Sonuç
Mike Strother
299 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-8, Martin Fall 2016 UMass Dartmouth, Team 5-8, Martin Fall 2016 üyesi
UMASSD-MARTIN-F16S5G8
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 9
Her zaman: 416
