Ana içeriğe geç
Toshiba Satellite R15-S829 RAM Replacement
Neye ihtiyacın var
  1. Toshiba Satellite R15-S829 RAM Replacement, Battery Replacement: adım 1, 1 resimden 1.
    • Unplug the charging cable from the laptop.
    • Turn off the laptop.
    • Turn the laptop over and locate the battery.
  2. Toshiba Satellite R15-S829 RAM Replacement: adım 2, 3 resimden 1. Toshiba Satellite R15-S829 RAM Replacement: adım 2, 3 resimden 2. Toshiba Satellite R15-S829 RAM Replacement: adım 2, 3 resimden 3.
    • Push the small switch near the corner of the laptop to the unlocked position.
    • Push the bigger switch in the direction of the icon and pull the battery away from the laptop.
  3. Toshiba Satellite R15-S829 RAM Replacement, RAM Replacement: adım 3, 2 resimden 1. Toshiba Satellite R15-S829 RAM Replacement, RAM Replacement: adım 3, 2 resimden 2.
    • Locate the cover where the RAM is located.
    • Locate the screw.
  4. Toshiba Satellite R15-S829 RAM Replacement: adım 4, 2 resimden 1. Toshiba Satellite R15-S829 RAM Replacement: adım 4, 2 resimden 2.
    • Loosen the screw for the cover. The screw is attached to the cover, so you don't need to worry about losing it.
    • Lift the cover.
  5. Toshiba Satellite R15-S829 RAM Replacement: adım 5, 3 resimden 1. Toshiba Satellite R15-S829 RAM Replacement: adım 5, 3 resimden 2. Toshiba Satellite R15-S829 RAM Replacement: adım 5, 3 resimden 3.
    • Push the two silver tabs outward so that the RAM can move upward.
    • Pull the first RAM module out of the socket.
  6. Toshiba Satellite R15-S829 RAM Replacement: adım 6, 3 resimden 1. Toshiba Satellite R15-S829 RAM Replacement: adım 6, 3 resimden 2. Toshiba Satellite R15-S829 RAM Replacement: adım 6, 3 resimden 3.
    • The second RAM is removed in the same way as the first.
    • Push the tabs outward and pull out the RAM.
Sonuç
Justin Slater
128 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-8, Martin Fall 2016 UMass Dartmouth, Team 5-8, Martin Fall 2016 üyesi
UMASSD-MARTIN-F16S5G8
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 147
