Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Toshiba Satellite Radius P55W-B5112 Battery Replacement
Neye ihtiyacın var
  1. Toshiba Satellite Radius P55W-B5112 Battery Replacement, Battery Replacement: adım 1, 3 resimden 1. Toshiba Satellite Radius P55W-B5112 Battery Replacement, Battery Replacement: adım 1, 3 resimden 2. Toshiba Satellite Radius P55W-B5112 Battery Replacement, Battery Replacement: adım 1, 3 resimden 3.
    • Unplug your laptop from any source of power.
    • Lay your laptop on a soft, clean surface as shown.
    • Using the metal spudger, remove the two rubber grips on the bottom face of the laptop, located closest to the hinge.
    • The grips may be brittle. Be careful when removing them with the metal spudger so as not to damage them.
  2. Toshiba Satellite Radius P55W-B5112 Battery Replacement: adım 2, 3 resimden 1. Toshiba Satellite Radius P55W-B5112 Battery Replacement: adım 2, 3 resimden 2. Toshiba Satellite Radius P55W-B5112 Battery Replacement: adım 2, 3 resimden 3.
    • Remove the ten 5mm Phillips #0 screws that secure the back plate to the computer.
  3. Toshiba Satellite Radius P55W-B5112 Battery Replacement: adım 3, 3 resimden 1. Toshiba Satellite Radius P55W-B5112 Battery Replacement: adım 3, 3 resimden 2. Toshiba Satellite Radius P55W-B5112 Battery Replacement: adım 3, 3 resimden 3.
    • Starting on the edge that is opposite the hinge, use the plastic opening tools to pry the back plate away from the computer.
    • Loosen the three non-hinge edges.
    • Leave a plastic opening tool in each corner to ensure that one side does not snap closed before you are done opening the others.
    • DO NOT lift the back plate away from the computer; it is still connected to the motherboard.
  4. Toshiba Satellite Radius P55W-B5112 Battery Replacement: adım 4, 3 resimden 1. Toshiba Satellite Radius P55W-B5112 Battery Replacement: adım 4, 3 resimden 2. Toshiba Satellite Radius P55W-B5112 Battery Replacement: adım 4, 3 resimden 3.
    • To loosen the back plate, lift it slightly and gently pull it away from the hinge.
    • Flip the back plate open towards the power button, but be sure to not pull on the ribbon cable that connects the back plate to the motherboard.
    • Use a plastic opening tool to detach the side of the ribbon cable connected to the computer by prying up gently on the small black lever at the point of attachment.
  5. Toshiba Satellite Radius P55W-B5112 Battery Replacement: adım 5, 3 resimden 1. Toshiba Satellite Radius P55W-B5112 Battery Replacement: adım 5, 3 resimden 2. Toshiba Satellite Radius P55W-B5112 Battery Replacement: adım 5, 3 resimden 3.
    • Remove the four 3mm Phillips #0 screws connecting the battery to the computer.
  6. Toshiba Satellite Radius P55W-B5112 Battery Replacement: adım 6, 3 resimden 1. Toshiba Satellite Radius P55W-B5112 Battery Replacement: adım 6, 3 resimden 2. Toshiba Satellite Radius P55W-B5112 Battery Replacement: adım 6, 3 resimden 3.
    • Use a plastic opening tool to lift the side of the battery that is closest to the long edge of the computer.
    • As you are pulling the battery away from the computer, unplug it from the side closest to the short edge of the computer.
    • There may be a lot of resistance when unplugging the battery. If there is, try to wiggle the male side of the plug back and forth as you remove it.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Mudassar Abbas Khan
624 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S66-G5, Rockett Fall 2017 UMass Dartmouth, Team S66-G5, Rockett Fall 2017 üyesi
UMASSD-ROCKETT-F17S66G5
3 Üyeler
Bir Yorum
Thanks for your support..
vamshikrishna oruganti - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 1,528
