Ana içeriğe geç
Toshiba Satellite Radius P55W-B5220 Motherboard Replacement
Neye ihtiyacın var
  1. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement, Motherboard: adım 1, 2 resimden 1. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement, Motherboard: adım 1, 2 resimden 2.
    • Using the plastic opening tool, remove the two rubber feet closest to the hinge.
  2. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove the 12 M2x4mm PH0 Philips screws.
  3. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: adım 3, 1 resimden 1.
    • Near the hinges, wedge a plastic opening tool under the back panel.
  4. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: adım 4, 1 resimden 1.
    • Unlatch the LED indicator from the back panel.
  5. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: adım 5, 1 resimden 1.
    • Using a P0 Philips head screwdriver, Remove the four M2x2.5mm P0 Philips screws from the battery.
  6. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: adım 6, 2 resimden 1. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: adım 6, 2 resimden 2.
    • Lift the battery.
    • Disconnect the battery.
  7. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: adım 7, 3 resimden 1. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: adım 7, 3 resimden 2. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: adım 7, 3 resimden 3.
    • Disconnect the ribbon cable of the touchpad from the motherboard.
  8. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: adım 8, 2 resimden 1. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: adım 8, 2 resimden 2.
    • Remove the two M2x2.5mm P0 Philips screws from the fan.
  9. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: adım 9, 3 resimden 1. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: adım 9, 3 resimden 2. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: adım 9, 3 resimden 3.
    • Disconnect the fan cables.
    • Carefully unhook the wires from the base of the fan.
  10. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: adım 10, 1 resimden 1.
    • Unscrew the four M2x4mm PH0 Philips screws from the CPU mounts on the motherboard.
  11. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: adım 11, 3 resimden 1. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: adım 11, 3 resimden 2. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: adım 11, 3 resimden 3.
    • Carefully lift the heatsink off the CPU.
    • Avoid bending or kinking the tubing.
    • Delicately lift the fan out with the heatsink.
  12. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: adım 12, 1 resimden 1.
    • Remove the M2x2.5mm P0 Philips screw from the USB controller.
  13. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: adım 13, 3 resimden 1. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: adım 13, 3 resimden 2. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: adım 13, 3 resimden 3.
    • Lift the USB controller from the motherboard.
    • Detach the USB controller from the motherboard.
  14. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: adım 14, 1 resimden 1.
    • Disconnect the left speaker from the motherboard.
  15. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: adım 15, 2 resimden 1. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: adım 15, 2 resimden 2.
    • Remove the two M2x4mm PH0 Philips screws for the speaker mounts.
  16. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: adım 16, 1 resimden 1.
    • Unhook the speaker from under the hinge cable mounts.
  17. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: adım 17, 1 resimden 1.
    • Unhook the right speaker cable from the motherboard.
  18. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: adım 18, 1 resimden 1.
    • Remove the copper tape from the speaker cord.
  19. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: adım 19, 2 resimden 1. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: adım 19, 2 resimden 2.
    • Unhook the speaker cables from under the catch under the hinge.
  20. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: adım 20, 1 resimden 1.
    • Remove the eight M2x2.5mm P0 Philips screws from the motherboard.
  21. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: adım 21, 1 resimden 1.
    • Remove the motherboard.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 1,642
