Ana içeriğe geç
Toshiba Satellite Radius P55W-B5220 RAM Replacement
Neye ihtiyacın var
  1. Toshiba Satellite Radius P55W-B5220 RAM Replacement, Back Cover: adım 1, 1 resimden 1.
    • Turn off the laptop before starting.
    • Remove the two rubber feet closest to the hinge with a plastic opening tool.
  2. Toshiba Satellite Radius P55W-B5220 RAM Replacement: adım 2, 1 resimden 1.
    • Remove the twelve M2x4mm PH0 Philips head screws.
  3. Toshiba Satellite Radius P55W-B5220 RAM Replacement: adım 3, 1 resimden 1.
    • Loosen the back cover with a plastic opening tool.
    • The least damaging way to pry the cover is to start from a corner and run the spudger along the edge.
    • Do not crack or bend the cover.
  4. Toshiba Satellite Radius P55W-B5220 RAM Replacement: adım 4, 1 resimden 1.
    • Carefully lift open the cover.
    • Remove the attached purple ribbon cable underneath the cover.
    • Do not rip the ribbon cable.
  5. Toshiba Satellite Radius P55W-B5220 RAM Replacement, RAM: adım 5, 2 resimden 1. Toshiba Satellite Radius P55W-B5220 RAM Replacement, RAM: adım 5, 2 resimden 2.
    • Push outward on the clamps holding the RAM in place.
  6. Toshiba Satellite Radius P55W-B5220 RAM Replacement: adım 6, 1 resimden 1.
    • Remove the RAM chips.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Devin Boski
478 İtibar
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 635
