Ana içeriğe geç
Toshiba Satellite S50-B Cooling Fan Replacement
Neye ihtiyacın var
  1. Toshiba Satellite S50-B Cooling Fan Replacement, Battery: adım 1, 2 resimden 1. Toshiba Satellite S50-B Cooling Fan Replacement, Battery: adım 1, 2 resimden 2.
    • Make sure you turn off the laptop first.
    • Unscrew the two 6.5mm screws below the battery using a Phillips #0 Screwdriver.
  2. Toshiba Satellite S50-B Cooling Fan Replacement: adım 2, 2 resimden 1. Toshiba Satellite S50-B Cooling Fan Replacement: adım 2, 2 resimden 2.
    • Place thumbs on corners of the battery. Pinch the battery between the thumb and index finger and pull.
  3. Toshiba Satellite S50-B Cooling Fan Replacement, Cooling Fan: adım 3, 3 resimden 1. Toshiba Satellite S50-B Cooling Fan Replacement, Cooling Fan: adım 3, 3 resimden 2. Toshiba Satellite S50-B Cooling Fan Replacement, Cooling Fan: adım 3, 3 resimden 3.
    • Locate the 10 screws on the bottom of the device, there should be 12 screws in total including the battery screws. Unscrew using a Phillips #0 screwdriver, and set screws aside.
    • Use a plastic opening tool to remove the bottom panel.
  4. Toshiba Satellite S50-B Cooling Fan Replacement: adım 4, 3 resimden 1. Toshiba Satellite S50-B Cooling Fan Replacement: adım 4, 3 resimden 2. Toshiba Satellite S50-B Cooling Fan Replacement: adım 4, 3 resimden 3.
    • Locate the 2 screws on each fan. Unscrew them.
    • Disconnect the fan by applying gentle pressure to the circled connection with your finger and pulling.
    • Remove the fans. Be sure to keep track of the right and left fans, marked R and L.
Sonuç
Bir başkası bu kılavuzu tamamladı.
diana calvo
144 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 15
Son 30 gün: 19
Her zaman: 1,544
