Ana içeriğe geç
Toshiba Satellite S50-B Hard Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite S50-B Hard Drive Replacement, Battery: adım 1, 2 resimden 1. Toshiba Satellite S50-B Hard Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Make sure you turn off the laptop first.
    • Unscrew the two 6.5mm screws below the battery using a Phillips #0 Screwdriver.
  2. Toshiba Satellite S50-B Hard Drive Replacement: adım 2, 2 resimden 1. Toshiba Satellite S50-B Hard Drive Replacement: adım 2, 2 resimden 2.
    • Place thumbs on corners of the battery. Pinch the battery between the thumb and index finger and pull.
  3. Toshiba Satellite S50-B Hard Drive Replacement, Hard Drive: adım 3, 3 resimden 1. Toshiba Satellite S50-B Hard Drive Replacement, Hard Drive: adım 3, 3 resimden 2. Toshiba Satellite S50-B Hard Drive Replacement, Hard Drive: adım 3, 3 resimden 3.
    • Locate the 12 screws on the bottom of the device. Unscrew using a Phillips screwdriver, and set screws aside.
    • Use a plastic opening tool to remove bottom casing.
  4. Toshiba Satellite S50-B Hard Drive Replacement: adım 4, 2 resimden 1. Toshiba Satellite S50-B Hard Drive Replacement: adım 4, 2 resimden 2.
    • Use the plastic casing over the hard drive to lift the hard drive up.
    • Once hard drive is slightly lifted up, make sure the laptop is in correct orientation with the battery away from you, and pull the hard drive towards right.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Victoria Murillo
143 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 41
Her zaman: 6,253
