Ana içeriğe geç
Toshiba Satellite S55T-B5335 Cooling Fans Replacement
Neye ihtiyacın var
  1. Toshiba Satellite S55T-B5335 Cooling Fans Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the two 7 mm Phillips #1 screws that hold the battery in place.
  2. Toshiba Satellite S55T-B5335 Cooling Fans Replacement: adım 2, 3 resimden 1. Toshiba Satellite S55T-B5335 Cooling Fans Replacement: adım 2, 3 resimden 2. Toshiba Satellite S55T-B5335 Cooling Fans Replacement: adım 2, 3 resimden 3.
    • Pull the battery from laptop.
  3. Toshiba Satellite S55T-B5335 Cooling Fans Replacement, Bottom Cover: adım 3, 2 resimden 1. Toshiba Satellite S55T-B5335 Cooling Fans Replacement, Bottom Cover: adım 3, 2 resimden 2.
    • Remove the ten 7 mm Phillips #1 screws that secure the back cover.
  4. Toshiba Satellite S55T-B5335 Cooling Fans Replacement: adım 4, 1 resimden 1.
    • Wedge the tip of a plastic opening tool between the back cover and the metal frame.
    • Twist the plastic opening tool, while wedged, in order to release the retaining tabs from the frame.
    • Repeat these steps in a circular pattern around the laptop to release all retaining tabs.
  5. Toshiba Satellite S55T-B5335 Cooling Fans Replacement: adım 5, 1 resimden 1.
    • Once all retaining tabs are released from the frame, you can pull up on the back cover to remove it.
  6. Toshiba Satellite S55T-B5335 Cooling Fans Replacement, Cooling Fans: adım 6, 1 resimden 1.
    • Remove the two 3.5 mm Phillips #1 screws that hold the cooling fan in place.
  7. Toshiba Satellite S55T-B5335 Cooling Fans Replacement: adım 7, 1 resimden 1.
    • Wedge the flat end of the spudger between the connector and its socket.
    • Twist back and forth in order to pry the connector loose from its socket.
    • Although you can pull on the connector wires to remove it from the socket, it is not recommended until the connector is loose to prevent damage to the wires.
  8. Toshiba Satellite S55T-B5335 Cooling Fans Replacement: adım 8, 1 resimden 1.
    • Lift up on the cooling fan to remove it from the laptop.
    • Repeat steps 6-8 for the other cooling fan.
Sonuç
Bir başkası bu kılavuzu tamamladı.
George Gillespie
721 İtibar
7 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-1, Blackwell Fall 2016 USF Tampa, Team 2-1, Blackwell Fall 2016 üyesi
USFT-BLACKWELL-F16S2G1
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 1,531
