Giriş
The touchpad is an input device that is sensitive to touch and allows the user to scroll and select. This is a simple but tedious part to replace as it requires patience when separating the adhesive from the touchpad. Please refer to the Touchpad Troubleshooting Guide to determine if your touchpad needs to be replaced.
Neye ihtiyacın var
Bu adımda kullanılan alet:Tweezers$4.99
Using a spudger, lift the black tab that holds the touchpad ribbon cable in place.
Using tweezers, pull gently on the purple tab to separate the ribbon cable from the connector.
