Ana içeriğe geç
Toshiba Satellite S55t-A5389 Keyboard Replacement
Neye ihtiyacın var
  1. Toshiba Satellite S55t-A5389 Keyboard Replacement, Keyboard: adım 1, 1 resimden 1.
    • Flip laptop over so that the bottom is facing upwards.
    • Remove the two 5mm Phillips #0 screws from the bottom of the laptop.
  2. Toshiba Satellite S55t-A5389 Keyboard Replacement: adım 2, 2 resimden 1. Toshiba Satellite S55t-A5389 Keyboard Replacement: adım 2, 2 resimden 2.
    • Flip the laptop over and open the display.
    • Insert a plastic opening tool into the gap found between the keyboard and top case.
    • Pry upwards until you hear a click and work your way around the perimeter of the keyboard.
  3. Toshiba Satellite S55t-A5389 Keyboard Replacement: adım 3, 3 resimden 1. Toshiba Satellite S55t-A5389 Keyboard Replacement: adım 3, 3 resimden 2. Toshiba Satellite S55t-A5389 Keyboard Replacement: adım 3, 3 resimden 3.
    • Lift the keyboard up, but not all the way since there's a ribbon cable attached underneath.
    • Underneath the keyboard is a ribbon cable that attaches it to the rest of the laptop.
    • Unlock the ribbon cable by lifting up the two small locks on both sides of the connector on the motherboard.
    • Once unlocked, remove the ribbon cable and keyboard from the laptop.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
William Mazanec
1.374 İtibar
8 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S5-G6, Passmore Spring 2018 USF Tampa, Team S5-G6, Passmore Spring 2018 üyesi
USFT-PASSMORE-S18S5G6
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 634
