Ana içeriğe geç
Toshiba Satellite S55t-A5389 Processor Replacement
Neye ihtiyacın var
  1. Toshiba Satellite S55t-A5389 Processor Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the fourteen 5mm Phillips #0 screws from the bottom of the laptop.
  2. Toshiba Satellite S55t-A5389 Processor Replacement: adım 2, 1 resimden 1.
    • Using the plastic prying tools, go around the edge of the bottom of the laptop to release the cover.
  3. Toshiba Satellite S55t-A5389 Processor Replacement: adım 3, 3 resimden 1. Toshiba Satellite S55t-A5389 Processor Replacement: adım 3, 3 resimden 2. Toshiba Satellite S55t-A5389 Processor Replacement: adım 3, 3 resimden 3.
    • Remove the four 5mm Phillips #0 screws from the battery.
    • Unplug the battery from the motherboard.
    • Remove the battery from the laptop.
  4. Toshiba Satellite S55t-A5389 Processor Replacement, Processor Fan: adım 4, 1 resimden 1.
    • Remove the two 5mm Phillips #0 screws from the fan.
  5. Toshiba Satellite S55t-A5389 Processor Replacement: adım 5, 1 resimden 1.
    • Disconnect the fan from the motherboard.
  6. Toshiba Satellite S55t-A5389 Processor Replacement: adım 6, 1 resimden 1.
    • Remove the four 5mm Phillips #0 screws from the heat pipe.
    • Remove the fan and heat pipe from the laptop.
  7. Toshiba Satellite S55t-A5389 Processor Replacement, Processor: adım 7, 1 resimden 1.
    • Rotate the lock 90 degrees using a Torx T8 in order to remove the processor.
  8. Toshiba Satellite S55t-A5389 Processor Replacement: adım 8, 1 resimden 1.
    • Carefully lift up the processor.
    • When putting the new processor on, make sure that the little arrow on the processor matches with the arrow on the socket
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
William Mazanec
1.350 İtibar
8 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S5-G6, Passmore Spring 2018 USF Tampa, Team S5-G6, Passmore Spring 2018 üyesi
USFT-PASSMORE-S18S5G6
3 Üyeler
Bir Yorum
Can i use i7 4940mx cpu on this laptop
Movies Star - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 633
