Ana içeriğe geç
Toshiba Satellite S55t-A5389 Wireless Network Card Replacement
Neye ihtiyacın var
  1. Toshiba Satellite S55t-A5389 Wireless Network Card Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the fourteen 5mm Phillips #0 screws from the bottom of the laptop.
  2. Toshiba Satellite S55t-A5389 Wireless Network Card Replacement: adım 2, 1 resimden 1.
    • Using the plastic prying tools, go around the edge of the bottom of the laptop to release the cover.
  3. Toshiba Satellite S55t-A5389 Wireless Network Card Replacement: adım 3, 3 resimden 1. Toshiba Satellite S55t-A5389 Wireless Network Card Replacement: adım 3, 3 resimden 2. Toshiba Satellite S55t-A5389 Wireless Network Card Replacement: adım 3, 3 resimden 3.
    • Remove the four 5mm Phillips #0 screws from the battery.
    • Unplug the battery from the motherboard.
    • Remove the battery from the laptop.
  4. Toshiba Satellite S55t-A5389 Wireless Network Card Replacement, Wireless Network Card: adım 4, 1 resimden 1.
    • Disconnect the black and white antenna wires from the wifi card.
  5. Toshiba Satellite S55t-A5389 Wireless Network Card Replacement: adım 5, 1 resimden 1.
    • Remove the 3mm Phillips #0 screw from the wifi card.
    • Remove the card from its socket.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
William Mazanec
1.374 İtibar
8 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S5-G6, Passmore Spring 2018 USF Tampa, Team S5-G6, Passmore Spring 2018 üyesi
USFT-PASSMORE-S18S5G6
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 1,752
