Giriş
If your Toshiba S55t-C5225 can no longer read CD’s/DVD’s or will not open then your optical disk drive is most likely not operational and needs to be replaced. The following steps are a guide to help the user in replacing the optical disk drive.
Neye ihtiyacın var
Carefully slide the optical disk drive to the right to remove from the motherboard.
Bir başkası bu kılavuzu tamamladı.
