Ana içeriğe geç
Toshiba Satellite S55t-C5225 Screen Assembly Replacement
Neye ihtiyacın var
  1. Toshiba Satellite S55t-C5225 Screen Assembly Replacement, Battery: adım 1, 1 resimden 1.
    • Shut down the computer and disconnect all cables
    • Flip the computer over so the bottom is facing up.
  2. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: adım 2, 2 resimden 1. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: adım 2, 2 resimden 2.
    • Remove the two 7.0 mm Phillips #0 screws that hold the battery in place.
  3. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: adım 3, 2 resimden 1. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: adım 3, 2 resimden 2.
    • Carefully remove the battery by wedging a plastic opening tool in-between the battery and back cover.
  4. Toshiba Satellite S55t-C5225 Screen Assembly Replacement, Back Panel: adım 4, 2 resimden 1. Toshiba Satellite S55t-C5225 Screen Assembly Replacement, Back Panel: adım 4, 2 resimden 2.
    • Remove the eleven 7.0 mm Phillips #0 screws that secure the back cover.
  5. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: adım 5, 2 resimden 1. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: adım 5, 2 resimden 2.
    • Wedge the tip of a plastic opening tool between the back cover and metal frame.
    • Twist the plastic tool, while wedged, to release the retaining tabs from the frame.
    • Repeat these steps around the laptop to release all retaining tabs.
  6. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: adım 6, 2 resimden 1. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: adım 6, 2 resimden 2.
    • Once all retaining tabs are released, pull up on the cover to remove.
  7. Toshiba Satellite S55t-C5225 Screen Assembly Replacement, Speakers: adım 7, 1 resimden 1.
    • Disconnect the power button strip by flipping up the white plastic clamp that connects it to the motherboard.
    • Pull the ribbon wire out from plastic clamp.
  8. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: adım 8, 2 resimden 1. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: adım 8, 2 resimden 2.
    • Remove the four 10.0 mm Phillips #0 screws that hold the speakers in place.
  9. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: adım 9, 2 resimden 1. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: adım 9, 2 resimden 2.
    • Follow the black wire that connects the speakers to the motherboard.
    • Pull the wire out from its socket to disconnect the speakers from the motherboard.
  10. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: adım 10, 2 resimden 1. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: adım 10, 2 resimden 2.
    • Lift speakers up from their mounted position to remove.
  11. Toshiba Satellite S55t-C5225 Screen Assembly Replacement, Screen Assembly: adım 11, 2 resimden 1. Toshiba Satellite S55t-C5225 Screen Assembly Replacement, Screen Assembly: adım 11, 2 resimden 2.
    • Disconnect LAN from the motherboard power wire. Pop up the white clamp that holds it in place, then pull the wire out.
  12. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: adım 12, 2 resimden 1. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: adım 12, 2 resimden 2.
    • Disconnect the two cables connecting the screen assembly to the WIFI card.
  13. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: adım 13, 3 resimden 1. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: adım 13, 3 resimden 2. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: adım 13, 3 resimden 3.
    • Disconnect all remaining cables that connect the screen assembly to the motherboard.
  14. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: adım 14, 1 resimden 1.
  15. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: adım 15, 2 resimden 1. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: adım 15, 2 resimden 2.
    • Remove the four 7.0 mm Phillips #0 screws on both ends of the laptop that attach the screen assembly to the laptop.
  16. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: adım 16, 3 resimden 1. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: adım 16, 3 resimden 2. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: adım 16, 3 resimden 3.
    • Slowly open laptop while the bottom is facing up. Begin to separate the bottom of laptop from the screen assembly brackets.
    • Remove the screen assembly.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Javien Delgado
220 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G5, Botvin Fall 2019 UMass Dartmouth, Team S1-G5, Botvin Fall 2019 üyesi
UMASSD-BOTVIN-F19S1G5
3 Üyeler
15 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 16
Her zaman: 845
