Giriş
This Replacement guide will be teaching you step by step how to replace the ram on you Toshiba Satellite S75D-A7346
Neye ihtiyacın var
First we have to take out the battery
Pull the switch on the left to the left
then hold the switch on the right to the right direction
then pull up the bttery from the point inbetween the 2 switches
Unscrew the screw located next to the information sticker
Then get a screw driver or prier to gently pry the covering plate
Gently move the 2 notches on the ends of each ram stick and the stick should pop out at a 30 degree angle
then pull that ram stick out
you can do the same to the other one
Insert the lowest ram stick first by inserting it at a 30 degree angle then push down on it
Note: do not put a lot of pressure on it
Note: make sure before you push it down the RAM stick is all the way in
Note: The maximum supported RAM is 8 GB in each slot of DDR3 1600Mhz
Put on the backplate and put pressure arround the edges of the blackplate so it stays flat with the case
Then screw in the screw next to the information sticker
Place the battery in the slot
Then hold the right switch to the right and push the battery in, then release the switch.
move the left switch to the right
