Ana içeriğe geç
Toshiba Satellite U405D-S2902 Battery Replacement
  1. Toshiba Satellite U405D-S2902 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure that the laptop is off and unplugged.
    • Turn the laptop over.
    • Slide back the left lock, and you should hear a click when it is successfully locked back in.
  2. Toshiba Satellite U405D-S2902 Battery Replacement: adım 2, 1 resimden 1.
    • Rotate the laptop 180 degrees so that the battery is near you.
    • Hold back the spring slide and pull the battery out.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Brandon Kirklen
311 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-8, Maness Winter 2013 Cal Poly, Team 7-8, Maness Winter 2013 üyesi
CPSU-MANESS-W13S7G8
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 507
