Ana içeriğe geç
Toshiba Satellite U405D-S2902 CD/DVD Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite U405D-S2902 CD/DVD Drive Replacement, Keyboard: adım 1, 3 resimden 1. Toshiba Satellite U405D-S2902 CD/DVD Drive Replacement, Keyboard: adım 1, 3 resimden 2. Toshiba Satellite U405D-S2902 CD/DVD Drive Replacement, Keyboard: adım 1, 3 resimden 3.
    • Situate the laptop so that it is open and the display is facing you.
    • Use the plastic opening tool to pry the black plastic insert upward. The insert can be found at the top of the keyboard.
    • Once the insert is loose, carefully remove it from the device.
  2. Toshiba Satellite U405D-S2902 CD/DVD Drive Replacement: adım 2, 2 resimden 1. Toshiba Satellite U405D-S2902 CD/DVD Drive Replacement: adım 2, 2 resimden 2.
    • Using #1 Phillips Screwdriver, remove both of the 5 mm screws that are located beneath the insert.
  3. Toshiba Satellite U405D-S2902 CD/DVD Drive Replacement: adım 3, 2 resimden 1. Toshiba Satellite U405D-S2902 CD/DVD Drive Replacement: adım 3, 2 resimden 2.
    • Use the plastic opening tool to begin removing the keys off of the device.
    • Once the keys are off, gently remove the keyboard. Be careful of the ribbon cable that still connects the keyboard to motherboard.
  4. Toshiba Satellite U405D-S2902 CD/DVD Drive Replacement: adım 4, 2 resimden 1. Toshiba Satellite U405D-S2902 CD/DVD Drive Replacement: adım 4, 2 resimden 2.
    • Lift up the gate on the ZIF socket to release the ribbon.
    • Ease the ribbon connecting the keyboard to the motherboard out of the ZIF socket.
  5. Toshiba Satellite U405D-S2902 CD/DVD Drive Replacement, CD/DVD Drive: adım 5, 2 resimden 1. Toshiba Satellite U405D-S2902 CD/DVD Drive Replacement, CD/DVD Drive: adım 5, 2 resimden 2.
    • With the keyboard removed, locate the marked screws.
    • Remove the marked 5mm screws using the #1 Phillips Screwdriver.
  6. Toshiba Satellite U405D-S2902 CD/DVD Drive Replacement: adım 6, 2 resimden 1. Toshiba Satellite U405D-S2902 CD/DVD Drive Replacement: adım 6, 2 resimden 2.
    • In the rectangular opening directly above the mouse pad, use the plastic opening tool to push up the tiny black gate of the ZIF socket (fancy name for the white connector).
    • Remove the ribbon from the ZIF socket.
  7. Toshiba Satellite U405D-S2902 CD/DVD Drive Replacement: adım 7, 2 resimden 1. Toshiba Satellite U405D-S2902 CD/DVD Drive Replacement: adım 7, 2 resimden 2.
    • Locate the wide opening at the top in the direction toward the screen.
    • Use the plastic opening tool to open the black ZIF gate.
    • Remove the blue ribbon.
  8. Toshiba Satellite U405D-S2902 CD/DVD Drive Replacement: adım 8, 2 resimden 1. Toshiba Satellite U405D-S2902 CD/DVD Drive Replacement: adım 8, 2 resimden 2.
    • Use the plastic opening tool to separate the top faceplate.
    • The faceplate consists of the entire shiny plastic surface and the holed metal center where the keyboard would normally be.
    • Carefully pry the faceplate away from the laptop's base by sliding the plastic opening tool around the perimeter of the entire device. You'll hear the sound of several clicks as you do this.
    • Prying apart the faceplate will take a little convincing, but be sure to not bend it too much. It would be a shame to put a crack in its glossy shine.
  9. Toshiba Satellite U405D-S2902 CD/DVD Drive Replacement: adım 9, 2 resimden 1. Toshiba Satellite U405D-S2902 CD/DVD Drive Replacement: adım 9, 2 resimden 2.
    • Gently lift the disk drive by its outward facing edge (the one with writing on it).
    • Pull the disk drive up and away from the laptop.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Brandon Kirklen
311 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-8, Maness Winter 2013 Cal Poly, Team 7-8, Maness Winter 2013 üyesi
CPSU-MANESS-W13S7G8
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 13
Her zaman: 430
