Ana içeriğe geç
Toshiba Satellite U405D-S2902 Display Replacement
Neye ihtiyacın var
  1. Toshiba Satellite U405D-S2902 Display Replacement, Display: adım 1, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Use tweezers to remove the small rubber covers over the screws on the top and bottom of the laptop case.
  2. Toshiba Satellite U405D-S2902 Display Replacement: adım 2, 2 resimden 1. Toshiba Satellite U405D-S2902 Display Replacement: adım 2, 2 resimden 2.
    • Use a #1 Phillips screwdriver to remove the 3mm screws located on both sides of the top of the laptop as well as the lower corners.
  3. Toshiba Satellite U405D-S2902 Display Replacement: adım 3, 3 resimden 1. Toshiba Satellite U405D-S2902 Display Replacement: adım 3, 3 resimden 2. Toshiba Satellite U405D-S2902 Display Replacement: adım 3, 3 resimden 3.
    • Use a plastic opening tool to separate the front plastic panel from the back side of the top of the laptop.
    • Carefully pull the top away from the back.
  4. Toshiba Satellite U405D-S2902 Display Replacement: adım 4, 3 resimden 1. Toshiba Satellite U405D-S2902 Display Replacement: adım 4, 3 resimden 2. Toshiba Satellite U405D-S2902 Display Replacement: adım 4, 3 resimden 3.
    • Turn the laptop around.
    • Remove the webcam/microphone data cable.
  5. Toshiba Satellite U405D-S2902 Display Replacement: adım 5, 2 resimden 1. Toshiba Satellite U405D-S2902 Display Replacement: adım 5, 2 resimden 2.
    • Remove the lower lighting power supply.
    • Remove the signal light power supply and data cable.
  6. Toshiba Satellite U405D-S2902 Display Replacement: adım 6, 2 resimden 1. Toshiba Satellite U405D-S2902 Display Replacement: adım 6, 2 resimden 2.
    • Locate and remove the four 2mm #1 Phillips screws around the sidewalls of the display.
    • After removing the last screw, the screen will be very loose, be sure to keep a hand on it to prevent it from damaging the keyboard.
  7. Toshiba Satellite U405D-S2902 Display Replacement: adım 7, 2 resimden 1. Toshiba Satellite U405D-S2902 Display Replacement: adım 7, 2 resimden 2.
    • Carefully remove the screen from the side brackets.
    • Remove the LCD ribbon connector from the display.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Brandon Kirklen
311 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-8, Maness Winter 2013 Cal Poly, Team 7-8, Maness Winter 2013 üyesi
CPSU-MANESS-W13S7G8
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 708
