Ana içeriğe geç
Toshiba Satellite U405D-S2902 Hard Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite U405D-S2902 Hard Drive Replacement, Hard Drive: adım 1, 2 resimden 1. Toshiba Satellite U405D-S2902 Hard Drive Replacement, Hard Drive: adım 1, 2 resimden 2.
    • Lay laptop on it's face and remove the two #1 Phillips screws in the back of the black plastic panel with a raised center.
    • The screws can not be removed from the panel, so loosen them until the panel can come off.
    • Carefully lift the panel using the thumb slot on the side closest to you while the battery is pointed out.
  2. Toshiba Satellite U405D-S2902 Hard Drive Replacement: adım 2, 1 resimden 1.
    • After lifting the cover up carefully, slide it to the left to be removed.
  3. Toshiba Satellite U405D-S2902 Hard Drive Replacement: adım 3, 3 resimden 1. Toshiba Satellite U405D-S2902 Hard Drive Replacement: adım 3, 3 resimden 2. Toshiba Satellite U405D-S2902 Hard Drive Replacement: adım 3, 3 resimden 3.
    • Place two fingers gently on the hard drive.
    • Slide it back to the left.
    • Lift the drive by the two corner tabs making sure not to touch the metel
    • Do not press down too hard on the top of the drive, or you will damage it. Only use enough pressure to be able to remove it from the SATA connection.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Brandon Kirklen
311 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-8, Maness Winter 2013 Cal Poly, Team 7-8, Maness Winter 2013 üyesi
CPSU-MANESS-W13S7G8
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 493
