Ana içeriğe geç
Toshiba Satellite U405D-S2902 Keyboard Replacement
Neye ihtiyacın var
  1. Toshiba Satellite U405D-S2902 Keyboard Replacement, Keyboard: adım 1, 3 resimden 1. Toshiba Satellite U405D-S2902 Keyboard Replacement, Keyboard: adım 1, 3 resimden 2. Toshiba Satellite U405D-S2902 Keyboard Replacement, Keyboard: adım 1, 3 resimden 3.
    • Situate the laptop so that it is open and the display is facing you.
    • Use the plastic opening tool to pry the black plastic insert upward. The insert can be found at the top of the keyboard.
    • Once the insert is loose, carefully remove it from the device.
  2. Toshiba Satellite U405D-S2902 Keyboard Replacement: adım 2, 2 resimden 1. Toshiba Satellite U405D-S2902 Keyboard Replacement: adım 2, 2 resimden 2.
    • Using #1 Phillips Screwdriver, remove both of the 5 mm screws that are located beneath the insert.
  3. Toshiba Satellite U405D-S2902 Keyboard Replacement: adım 3, 2 resimden 1. Toshiba Satellite U405D-S2902 Keyboard Replacement: adım 3, 2 resimden 2.
    • Use the plastic opening tool to begin removing the keys off of the device.
    • Once the keys are off, gently remove the keyboard. Be careful of the ribbon cable that still connects the keyboard to motherboard.
  4. Toshiba Satellite U405D-S2902 Keyboard Replacement: adım 4, 2 resimden 1. Toshiba Satellite U405D-S2902 Keyboard Replacement: adım 4, 2 resimden 2.
    • Lift up the gate on the ZIF socket to release the ribbon.
    • Ease the ribbon connecting the keyboard to the motherboard out of the ZIF socket.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Brandon Kirklen
311 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-8, Maness Winter 2013 Cal Poly, Team 7-8, Maness Winter 2013 üyesi
CPSU-MANESS-W13S7G8
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 627
