Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
The RAM is the amount of data that can be accessed at the same time. By upgrading this, you will be able to multitask and run more programs without slowing down the computer. Before beginning this guide, make sure to have purchased the memory board you wish to install.
  1. Lay the device face down with the battery facing away from you. Locate the center panel. It will have two vents in it and three screws on the left side. Loosen the three screws that hold the rear access panel on, using your Phillips #1 Screwdriver.
    • Lay the device face down with the battery facing away from you. Locate the center panel. It will have two vents in it and three screws on the left side.
    • Loosen the three screws that hold the rear access panel on, using your Phillips #1 Screwdriver.
    • The screws will not actually come out from the panel but will be loose and let the panel come off.
    • Lift the left side of the panel to remove it.
  2. Locate and pull back the two mounting clips on either side of the memory chip.
    • Locate and pull back the two mounting clips on either side of the memory chip.
    • Be sure that when replacing the board, push down gently until the clips snap back in.
  3. Lift RAM circuit board to about a 45 degree angle and pull gently to the right. Lift RAM circuit board to about a 45 degree angle and pull gently to the right.
    • Lift RAM circuit board to about a 45 degree angle and pull gently to the right.
Sonuç
That's it for hardware, the remaining steps will depend on the software platform being run on your laptop.
2 farklı kişi bu kılavuzu tamamladı.
Brandon Kirklen
290 İtibar
8 adet Kılavuz yazıldı
Takım
Cal Poly, Team 7-8, Maness Winter 2013 Cal Poly, Team 7-8, Maness Winter 2013 üyesi
CPSU-MANESS-W13S7G8
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 477
