Ana içeriğe geç
Toshiba Satellite U925T-S2120 Battery Replacement
Neye ihtiyacın var
  1. Toshiba Satellite U925T-S2120 Battery  Replacement, Battery: adım 1, 2 resimden 1. Toshiba Satellite U925T-S2120 Battery  Replacement, Battery: adım 1, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use tweezers to remove the nine rubber grip pads on the back panel of the laptop.
  2. Toshiba Satellite U925T-S2120 Battery  Replacement: adım 2, 3 resimden 1. Toshiba Satellite U925T-S2120 Battery  Replacement: adım 2, 3 resimden 2. Toshiba Satellite U925T-S2120 Battery  Replacement: adım 2, 3 resimden 3.
    • Use a Philips #1 screwdriver to remove the nine 5.8 mm screws highlighted.
    • Remove the two 6.8 mm screws. Set aside.
    Notice: The U920T need a T7 screwdriver for the top middle screw.
    Michael Jakobsen - Yanıt
  3. Toshiba Satellite U925T-S2120 Battery  Replacement: adım 3, 2 resimden 1. Toshiba Satellite U925T-S2120 Battery  Replacement: adım 3, 2 resimden 2.
    • Remove the back panel by inserting the plastic opening tool into the seam of the laptop and pushing downwards.
  4. Toshiba Satellite U925T-S2120 Battery  Replacement: adım 4, 1 resimden 1.
    • Use the screwdriver to remove the two 3.4 mm screws highlighted.
  5. Toshiba Satellite U925T-S2120 Battery  Replacement: adım 5, 2 resimden 1. Toshiba Satellite U925T-S2120 Battery  Replacement: adım 5, 2 resimden 2.
    • Remove the black cable from the connector. Pull in the same direction as the black wiring runs.
    • Excessive force in this step may damage the wires and/or your device.
  6. Toshiba Satellite U925T-S2120 Battery  Replacement: adım 6, 2 resimden 1. Toshiba Satellite U925T-S2120 Battery  Replacement: adım 6, 2 resimden 2.
    • Lift and remove the battery from the device with the iFixit opening tool.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Sonia Shah
224 İtibar
1 Kılavuz yazıldı
Ekip
Baylor, Team S5-G5, Williams Spring 2017 Baylor, Team S5-G5, Williams Spring 2017 üyesi
BU-WILLIAMS-S17S5G5
3 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
Super helpful.
Operetka - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 2,379
