Ana içeriğe geç
Toshiba Satellite U925T-S2120 Hard Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite U925T-S2120 Hard Drive Replacement, Hard Drive: adım 1, 2 resimden 1. Toshiba Satellite U925T-S2120 Hard Drive Replacement, Hard Drive: adım 1, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use tweezers to pinch and pull out and remove the nine rubber gripper pads on the back panel of the laptop. Set aside.
  2. Toshiba Satellite U925T-S2120 Hard Drive Replacement: adım 2, 3 resimden 1. Toshiba Satellite U925T-S2120 Hard Drive Replacement: adım 2, 3 resimden 2. Toshiba Satellite U925T-S2120 Hard Drive Replacement: adım 2, 3 resimden 3.
    • Unscrew nine 5.8 mm screws using a PH1 screwdriver and turning clockwise.
    • Use the same screwdriver to remove the two 6.8 mm screws.
  3. Toshiba Satellite U925T-S2120 Hard Drive Replacement: adım 3, 2 resimden 1. Toshiba Satellite U925T-S2120 Hard Drive Replacement: adım 3, 2 resimden 2.
    • Remove the back panel open by inserting the plastic opening tool into the seam of the laptop and pushing downwards. Repeat the motion around the perimeter of the device.
  4. Toshiba Satellite U925T-S2120 Hard Drive Replacement: adım 4, 1 resimden 1.
    • Gently pop out the tab connected to the orange plastic strip.
  5. Toshiba Satellite U925T-S2120 Hard Drive Replacement: adım 5, 1 resimden 1.
    • Hold back the orange plastic strip with one hand
    • Use a PH1 screwdriver to unscrew the two 3.4 mm screws by turning clockwise.
  6. Toshiba Satellite U925T-S2120 Hard Drive Replacement: adım 6, 1 resimden 1.
    • Lift the silver flap away from the hard drive.
    • Gently pinch and lift out the hard drive with your thumb and pointer finger.
  7. Toshiba Satellite U925T-S2120 Hard Drive Replacement: adım 7, 1 resimden 1.
    • Completely remove the hard drive from the device.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Terry
137 İtibar
1 Kılavuz yazıldı
Ekip
Baylor, Team S5-G5, Williams Spring 2017 Baylor, Team S5-G5, Williams Spring 2017 üyesi
BU-WILLIAMS-S17S5G5
3 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 19
Her zaman: 1,920
