Giriş
In this guide you will learn how to remove the heat sink of your Toshiba Satellite U925T-S2120. If your heat sink is clogged or broken, you may need to replace it. Before beginning this guide you should have all required tools that are listed.
Neye ihtiyacın var
Bu adımda kullanılan alet:Tweezers$4.99
Use tweezers to remove the nine rubber grip pads on the back panel of the laptop.
Bir başkası bu kılavuzu tamamladı.
