Ana içeriğe geç
Toshiba Satellite U925T-S2120 RAM Replacement
Neye ihtiyacın var
  1. Toshiba Satellite U925T-S2120 RAM Replacement, RAM: adım 1, 2 resimden 1. Toshiba Satellite U925T-S2120 RAM Replacement, RAM: adım 1, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Remove the 9 rubber gripper pads on the back panel of the laptop using tweezers.
  2. Toshiba Satellite U925T-S2120 RAM Replacement: adım 2, 3 resimden 1. Toshiba Satellite U925T-S2120 RAM Replacement: adım 2, 3 resimden 2. Toshiba Satellite U925T-S2120 RAM Replacement: adım 2, 3 resimden 3.
    • Unscrew nine 5.8 mm screws by turning a PH1 screwdriver clockwise after inserting it into the screw.
    • Unscrew two 6.8 mm screws by turning a PH1 screwdriver clockwise after inserting it into the screw.
  3. Toshiba Satellite U925T-S2120 RAM Replacement: adım 3, 2 resimden 1. Toshiba Satellite U925T-S2120 RAM Replacement: adım 3, 2 resimden 2.
    • Take off the back panel open by sticking the plastic opening tool into the seam of the laptop, and pushing the opening tool downwards.
  4. Toshiba Satellite U925T-S2120 RAM Replacement: adım 4, 2 resimden 1. Toshiba Satellite U925T-S2120 RAM Replacement: adım 4, 2 resimden 2.
    • Gently pinch the RAM with your thumb and pointer finger.
    • Pull the RAM out of the logic board with gentle force.
    • Try to keep the RAM parallel as you pull it out, so that the RAM does not chip.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Andrew Honderich
364 İtibar
3 adet Kılavuz yazıldı
Ekip
Baylor, Team S5-G5, Williams Spring 2017 Baylor, Team S5-G5, Williams Spring 2017 üyesi
BU-WILLIAMS-S17S5G5
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 592
