Ana içeriğe geç
Giriş
If you are encountering problems with the battery, and need to replace or remove it, follow the instructions provided in this guide. Make sure to read the safety guide before attempting the steps outlined below.
Aletler
Hiçbir alet belirtilmedi.
Parçalar
  1. Unplug the laptop and turn it off.
    • Unplug the laptop and turn it off.
    • Flip the laptop upside down.
    • Locate the battery on the underside of the laptop.
  2. Push the two latches away from the battery.
    • Push the two latches away from the battery.
  3. Slide the battery away from the laptop. Locate the serial number on the battery to order a replacement.
    • Slide the battery away from the laptop.
    • Locate the serial number on the battery to order a replacement.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Brenna Callahan
841 İtibar
5 adet Kılavuz yazıldı
Takım
UMass Dartmouth, Team 5-2, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-2, Gulbrandsen Fall 2015 üyesi
UMASSD-GULBRANDSEN-F15S5G2
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 397
