Ana içeriğe geç
Toshiba Satellite c650d Fan Replacement
Neye ihtiyacın var
  1. Toshiba Satellite c650d Fan Replacement, Battery: adım 1, 1 resimden 1.
    • Unplug the laptop and turn it off.
    • Flip the laptop upside down.
    • Locate the battery on the underside of the laptop.
  2. Toshiba Satellite c650d Fan Replacement: adım 2, 1 resimden 1.
    • Push the two latches away from the battery.
  3. Toshiba Satellite c650d Fan Replacement: adım 3, 2 resimden 1. Toshiba Satellite c650d Fan Replacement: adım 3, 2 resimden 2.
    • Slide the battery away from the laptop.
    • Locate the serial number on the battery to order a replacement.
  4. Toshiba Satellite c650d Fan Replacement, Keyboard: adım 4, 1 resimden 1.
    • Remove the fourteen 6.0mm and two 2.0mm Philip's #0 screws connecting the keyboard to the back.
    • Make sure you keep track of all the screws.
  5. Toshiba Satellite c650d Fan Replacement: adım 5, 1 resimden 1.
    • Flip the computer over.
    • Use a nylon spudger to lift the keyboard.
    • Go around the edge of the keyboard and lift until the keyboard separates from the back.
    • Only lift the keyboard a little at a time, otherwise you risk damaging the plastic.
  6. Toshiba Satellite c650d Fan Replacement: adım 6, 1 resimden 1.
    • Detach the ribbon cable that connects the keyboard to the motherboard.
  7. Toshiba Satellite c650d Fan Replacement, Fan: adım 7, 1 resimden 1.
    • Detach the cable connecting the fan to the motherboard.
  8. Toshiba Satellite c650d Fan Replacement: adım 8, 2 resimden 1. Toshiba Satellite c650d Fan Replacement: adım 8, 2 resimden 2.
    • Remove the one 3.0mm and one 5.0mm Philips #0 screws holding the fan in place.
  9. Toshiba Satellite c650d Fan Replacement: adım 9, 1 resimden 1.
    • Remove the fan by pulling it out slowly.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Brenna Callahan
868 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-2, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-2, Gulbrandsen Fall 2015 üyesi
UMASSD-GULBRANDSEN-F15S5G2
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 1,479
