Ana içeriğe geç
Toshiba Satellite c650d Keyboard Replacement
Neye ihtiyacın var
  1. Toshiba Satellite c650d Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Unplug the laptop and turn it off.
    • Flip the laptop upside down.
    • Locate the battery on the underside of the laptop.
  2. Toshiba Satellite c650d Keyboard Replacement: adım 2, 1 resimden 1.
    • Push the two latches away from the battery.
  3. Toshiba Satellite c650d Keyboard Replacement: adım 3, 2 resimden 1. Toshiba Satellite c650d Keyboard Replacement: adım 3, 2 resimden 2.
    • Slide the battery away from the laptop.
    • Locate the serial number on the battery to order a replacement.
  4. Toshiba Satellite c650d Keyboard Replacement, Keyboard: adım 4, 1 resimden 1.
    • Remove the fourteen 6.0mm and two 2.0mm Philip's #0 screws connecting the keyboard to the back.
    • Make sure you keep track of all the screws.
  5. Toshiba Satellite c650d Keyboard Replacement: adım 5, 1 resimden 1.
    • Flip the computer over.
    • Use a nylon spudger to lift the keyboard.
    • Go around the edge of the keyboard and lift until the keyboard separates from the back.
    • Only lift the keyboard a little at a time, otherwise you risk damaging the plastic.
  6. Toshiba Satellite c650d Keyboard Replacement: adım 6, 1 resimden 1.
    • Detach the ribbon cable that connects the keyboard to the motherboard.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Brenna Callahan
868 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-2, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-2, Gulbrandsen Fall 2015 üyesi
UMASSD-GULBRANDSEN-F15S5G2
3 Üyeler
10 adet Kılavuz yazıldı
4Kılavuz Yorumları
this is completely wrong, remove the strip above keyboard, unscrew the screws, lift keyboard up gently, remove ribbon cable by flipping up the catch, all should be done VERY gently
one78point4 - Yanıt
VERY TRUE . But fitted a new keyboard and it still can,t use numbers one to five or the space bar unless i use the FN button.
jcampbell1950 - Yanıt
Just proceeded as one78point4 commented and although it's a Toshiba L300, it took me less than 5 minutes to fix my keyboard's issue, which was in fact a disconnected ribbon (strange though...sabotage?)
Anyway...thanks a million to you one78point4!!!
calipha - Yanıt
as one78point4 commented this is total overkill and not at all correct, most Toshibas keyboards are removed in the way described by one78point4 and I should know I’ve replaced enough of them over the last 20 yrs, although later laptops are heaps easier than the old one.
transtasmancomputers - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 1,766
