Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Unplug the laptop and turn it off.
Flip the laptop upside down.
Locate the battery on the underside of the laptop.
Slide the battery away from the laptop.
Locate the serial number on the battery to order a replacement.
Remove the fourteen 6.0mm and two 2.0mm Philip's #0 screws connecting the keyboard to the back.
Flip the computer over.
Use a nylon spudger to lift the keyboard.
Go around the edge of the keyboard and lift until the keyboard separates from the back.
Detach the ribbon cable that connects the keyboard to the motherboard.
3 farklı kişi bu kılavuzu tamamladı.
4 Yorum
this is completely wrong, remove the strip above keyboard, unscrew the screws, lift keyboard up gently, remove ribbon cable by flipping up the catch, all should be done VERY gently
VERY TRUE . But fitted a new keyboard and it still can,t use numbers one to five or the space bar unless i use the FN button.
as one78point4 commented this is total overkill and not at all correct, most Toshibas keyboards are removed in the way described by one78point4 and I should know I’ve replaced enough of them over the last 20 yrs, although later laptops are heaps easier than the old one.
