Ana içeriğe geç
Toshiba Satellite p875 s7200 Disk Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite p875 s7200 Disk Drive Replacement, Disk Drive: adım 1, 1 resimden 1.
    • Remember to remove any disks from the disk drive
    • Remove the battery by sliding the tabs to the left.
    • Use the spudger to lift the battery out.
  2. Toshiba Satellite p875 s7200 Disk Drive Replacement: adım 2, 1 resimden 1.
    • Use the Phillips head screw driver to remove the screw holding the back plate on.
    • Use the spudger to remove the back plate.
  3. Toshiba Satellite p875 s7200 Disk Drive Replacement: adım 3, 1 resimden 1.
    • Use the Phillips head screw driver to remove the 6mm screw holding the disk drive in.
  4. Toshiba Satellite p875 s7200 Disk Drive Replacement: adım 4, 1 resimden 1.
    • Removed Disk Drive.
Sonuç
Danny Amado
823 İtibar
5 adet Kılavuz yazıldı
Ekip
Baylor, Team S1-G3, Williams Fall 2018 Baylor, Team S1-G3, Williams Fall 2018 üyesi
BU-WILLIAMS-F18S1G3
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 9
Her zaman: 286
