Ana içeriğe geç
Toshiba Satellite p875 s7200 RAM Stick Replacement
Neye ihtiyacın var
  1. Toshiba Satellite p875 s7200 RAM Stick Replacement, RAM Stick: adım 1, 1 resimden 1.
    • Remove the battery by sliding the tabs to the left.
    • Use the spudger to lift the battery out.
  2. Toshiba Satellite p875 s7200 RAM Stick Replacement: adım 2, 1 resimden 1.
    • Use the Phillips head screw driver to remove the screw holding the back plate on.
    • Use the spudger to remove the back plate.
  3. Toshiba Satellite p875 s7200 RAM Stick Replacement: adım 3, 1 resimden 1.
    • Unlock the RAM by lightly pushing the two metallic holding arms away from the RAM stick.
    • The holding arms can be pressed together or one at a time.
    • The RAM sticks one of its edges slightly away away from the computer when unlocked.
  4. Toshiba Satellite p875 s7200 RAM Stick Replacement: adım 4, 1 resimden 1.
    • Grab the RAM stick by the protruding edge.
    • Pull the RAM stick towards the right to remove.
Sonuç
Danny Amado
823 İtibar
5 adet Kılavuz yazıldı
Ekip
Baylor, Team S1-G3, Williams Fall 2018 Baylor, Team S1-G3, Williams Fall 2018 üyesi
BU-WILLIAMS-F18S1G3
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 8
Her zaman: 402
