Ana içeriğe geç
Toshiba Stor.E Alu 2S Disassembly
Neye ihtiyacın var
  1. Toshiba Stor.E Alu 2S Disassembly, Toshiba Stor.E Alu 2S Disassembly: adım 1, 2 resimden 1. Toshiba Stor.E Alu 2S Disassembly, Toshiba Stor.E Alu 2S Disassembly: adım 1, 2 resimden 2.
    • This is the portable HDD we start with. Your version may look different as they come white, silver or black. Anyway this tutorial will work on all of them without anyone bleeding.
  2. Toshiba Stor.E Alu 2S Disassembly: adım 2, 1 resimden 1.
    • First we search for these notches. They are postitioned on the side of the case and there are four of them. Do you see them?
  3. Toshiba Stor.E Alu 2S Disassembly: adım 3, 3 resimden 1. Toshiba Stor.E Alu 2S Disassembly: adım 3, 3 resimden 2. Toshiba Stor.E Alu 2S Disassembly: adım 3, 3 resimden 3.
    • We try to open the case by widening the outer frame with our sharp fingernails (alternatively you may use any sharp tool, but that might hurt this beautiful case...).
    • Keep in mind that there are two seperate halves of the outer case.
    • I've included photos of the edges that hold the outer case tight. Maybe knowing about those will help you.
  4. Toshiba Stor.E Alu 2S Disassembly: adım 4, 1 resimden 1.
    • Making progress?
  5. Toshiba Stor.E Alu 2S Disassembly: adım 5, 3 resimden 1. Toshiba Stor.E Alu 2S Disassembly: adım 5, 3 resimden 2. Toshiba Stor.E Alu 2S Disassembly: adım 5, 3 resimden 3.
    • Once you have opened the first half of the case, repeat for the other one.
    • Isn't it beautiful?
  6. Toshiba Stor.E Alu 2S Disassembly: adım 6, 2 resimden 1. Toshiba Stor.E Alu 2S Disassembly: adım 6, 2 resimden 2.
    • What we see now are the inner frame, the HDD and the SATA-USB-Adapter. The last one will leave shortly.
    • If you don't see the same side of your disk as there is on the photo, turn it on its back.
    • You now need your crossed screwdriver to screw the screw I've marked.
  7. Toshiba Stor.E Alu 2S Disassembly: adım 7, 1 resimden 1.
    • Well I hope you screwed this up until now.
  8. Toshiba Stor.E Alu 2S Disassembly: adım 8, 2 resimden 1. Toshiba Stor.E Alu 2S Disassembly: adım 8, 2 resimden 2.
    • Now we continue to remove the plastic inner frame
    • See those buggers I've marked with arrows?
    • Are you sure?
    • There are four of them.
    • Really found all?
  9. Toshiba Stor.E Alu 2S Disassembly: adım 9, 1 resimden 1.
    • Use the flathead screwdriver or any sufficient tool as a lever and bend the frame outwards.
    • Easy huh?
  10. Toshiba Stor.E Alu 2S Disassembly: adım 10, 2 resimden 1. Toshiba Stor.E Alu 2S Disassembly: adım 10, 2 resimden 2.
    • Repeat this for all buggers, you end up with the HDD + SATA-USB-Adapter and the plastic frame
  11. Toshiba Stor.E Alu 2S Disassembly: adım 11, 1 resimden 1.
    • Now remove the USB-SATA-Adapter. You can do this by hand. I believe in you.
  12. Toshiba Stor.E Alu 2S Disassembly: adım 12, 1 resimden 1.
    • I am so proud of you.
  13. Toshiba Stor.E Alu 2S Disassembly: adım 13, 2 resimden 1. Toshiba Stor.E Alu 2S Disassembly: adım 13, 2 resimden 2.
    • Yeah you did it! I hope you enjoyed this teardown :)
    • If you have any questions regarding the photos (there are more, I own them), my text and instructions or my mental health feel free to message me!
Bitiş Çizgisi
14 farklı kişi bu kılavuzu tamamladı.
Niels
521 İtibar
1 Kılavuz yazıldı
3Kılavuz Yorumları
5 years ago but perfect still for a random job I had for it thankyou
steel city domains - Yanıt
My portable hard disk can not be used as internal hard / secondary hard disk. What should I do
himanshu bakshi - Yanıt
How do you fix it? It's not loading.
Rob Wynn - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 37
Son 30 gün: 194
Her zaman: 14,178
