Ana içeriğe geç
Toshiba T2400CS Hard drive Replacement
Neye ihtiyacın var
  1. Toshiba T2400CS Hard drive Replacement, Removing the battery: adım 1, 1 resimden 1.
    • 1.A) Slide the little plastic cover forward
    • 1.B) Push the button underneath the cover
    • 1.C) Slide the battery out
  2. Toshiba T2400CS Hard drive Replacement, Undo the screws on the bottom of the laptop: adım 2, 1 resimden 1.
    • The bottom of the laptop has 6 visible screws and the 7th one is hidden under the battery
  3. Toshiba T2400CS Hard drive Replacement, Undo the screws on the back of the laptop: adım 3, 1 resimden 1.
    • The back of the laptop has 2 screws.
  4. Toshiba T2400CS Hard drive Replacement, Removing the palmrest: adım 4, 1 resimden 1.
    • 4.A) Gently lift the bottom of the palmrest up
    • 4.B) Carefully pull the palmrest toward yourself, dislodging it from the top half of the case
  5. Toshiba T2400CS Hard drive Replacement, Removing the keyboard: adım 5, 1 resimden 1.
    • 5.A) Gently release the ribbon cable tabs and pull the ribbon cable out
    • 5.B) Raise the bottom of the keyboard and pull it out of the case
  6. Toshiba T2400CS Hard drive Replacement, Release the top part of the case: adım 6, 1 resimden 1.
    • 6.A) Undo the screw
    • 6.B) Gently use a flat tool to pull back the plastic tabs, releasing the sides
  7. Toshiba T2400CS Hard drive Replacement, Remove the top part of the case: adım 7, 1 resimden 1.
    • 7.A) Carefully pull the bottom of the top part up
    • 7.B) Gently pull up and toward yourself to remove the part
  8. Toshiba T2400CS Hard drive Replacement, Prepare to remove the daughter board: adım 8, 2 resimden 1. Toshiba T2400CS Hard drive Replacement, Prepare to remove the daughter board: adım 8, 2 resimden 2.
    • 8.A) Undo all the highlighted screws
    • 8.B) Carefully release the CMOS battery cable from the board
    • 8.C) (optional) Lift up and remove the bottom right latch piece
  9. Toshiba T2400CS Hard drive Replacement, Remove the daughter board: adım 9, 1 resimden 1.
    • Carefully but firmly lift up the top part of the daughter board by the corners from it's connector and lift the entire board out of the case.
  10. Toshiba T2400CS Hard drive Replacement, Remove the hard drive: adım 10, 1 resimden 1.
    • 10.A) Undo the screws holding the hard drive bracket in place
    • 10.B) Slide the hard drive toward yourself to release it from the connector
  11. Toshiba T2400CS Hard drive Replacement: adım 11, 2 resimden 1. Toshiba T2400CS Hard drive Replacement: adım 11, 2 resimden 2.
    • Undo the screws on each side of the bracket and your hard drive is free!
    • To reassemble the computer with a new hard drive, repeat the steps backwards.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
slydoge
253 İtibar
1 Kılavuz yazıldı
1Rehber Yorum
Thanks mom very cool
Bunneh 4444 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 17
Her zaman: 691
