Ana içeriğe geç
Toshiba TDP-XP2 Fuse Replacement
Neye ihtiyacın var
  1. Toshiba TDP-XP2 Fuse Replacement, Fuse: adım 1, 3 resimden 1. Toshiba TDP-XP2 Fuse Replacement, Fuse: adım 1, 3 resimden 2. Toshiba TDP-XP2 Fuse Replacement, Fuse: adım 1, 3 resimden 3.
    • Start by removing the two screws on the bottom of the device as shown.
  2. Toshiba TDP-XP2 Fuse Replacement: adım 2, 2 resimden 1. Toshiba TDP-XP2 Fuse Replacement: adım 2, 2 resimden 2.
    • Remove the top plastic cover from the device. The back is snapped on so it would help to have leverage from a prying tool.
    • Remove the ribbon cable attached to the plastic piece just removed. Remember its orientation for re-assembling later.
  3. Toshiba TDP-XP2 Fuse Replacement: adım 3, 3 resimden 1. Toshiba TDP-XP2 Fuse Replacement: adım 3, 3 resimden 2. Toshiba TDP-XP2 Fuse Replacement: adım 3, 3 resimden 3.
    • Remove the screws from the case located around the device.
  4. Toshiba TDP-XP2 Fuse Replacement: adım 4, 1 resimden 1.
    • Remove the plastic panels from the body.
  5. Toshiba TDP-XP2 Fuse Replacement: adım 5, 3 resimden 1. Toshiba TDP-XP2 Fuse Replacement: adım 5, 3 resimden 2. Toshiba TDP-XP2 Fuse Replacement: adım 5, 3 resimden 3.
    • Remove the screws from the IO panel.
    • Pull up on the panel and remove it.
  6. Toshiba TDP-XP2 Fuse Replacement: adım 6, 2 resimden 1. Toshiba TDP-XP2 Fuse Replacement: adım 6, 2 resimden 2.
    • Unscrew the screws from the metal shielding to remove it.
  7. Toshiba TDP-XP2 Fuse Replacement: adım 7, 3 resimden 1. Toshiba TDP-XP2 Fuse Replacement: adım 7, 3 resimden 2. Toshiba TDP-XP2 Fuse Replacement: adım 7, 3 resimden 3.
    • Remove cables from motherboard.
    • Unscrew motherboard and remove from device.
  8. Toshiba TDP-XP2 Fuse Replacement: adım 8, 1 resimden 1.
    • Remove the cable from the bottom of the motherboard to fully remove it.
  9. Toshiba TDP-XP2 Fuse Replacement: adım 9, 1 resimden 1.
    • Unscrew the power adapter on the back.
  10. Toshiba TDP-XP2 Fuse Replacement: adım 10, 2 resimden 1. Toshiba TDP-XP2 Fuse Replacement: adım 10, 2 resimden 2.
    • Remove cables from the power supply board.
    • Remove the screws located around the board to un-mount it.
  11. Toshiba TDP-XP2 Fuse Replacement: adım 11, 2 resimden 1. Toshiba TDP-XP2 Fuse Replacement: adım 11, 2 resimden 2.
    • Locate the fuse near where the power adapter was.
    • De-solder the fuse and replace with an equivalent fuse (Fuse leads to de-solder are marked in red).
Sonuç
Bryan Underwood
697 İtibar
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 413
