Ana içeriğe geç
Toshiba TECRA R940 Back Panel Replacement
Neye ihtiyacın var
  1. Toshiba TECRA R940 Back Panel Replacement, Battery: adım 1, 2 resimden 1. Toshiba TECRA R940 Back Panel Replacement, Battery: adım 1, 2 resimden 2.
    • Slide lock 1, located on the right side, to the unlocked position.
  2. Toshiba TECRA R940 Back Panel Replacement: adım 2, 2 resimden 1. Toshiba TECRA R940 Back Panel Replacement: adım 2, 2 resimden 2.
    • While holding lock 2 (left side) in the unlocked position, pull out the battery pack.
    • It is not necessary to hold open lock 2 for re-installation.
  3. Toshiba TECRA R940 Back Panel Replacement, Back Panel: adım 3, 2 resimden 1. Toshiba TECRA R940 Back Panel Replacement, Back Panel: adım 3, 2 resimden 2.
    • Unscrew the single screw on the RAM access panel using a Phillips #0 screwdriver.
    • The screw will not come apart from the panel.
    • Use a plastic opening tool to pry off the access panel.
  4. Toshiba TECRA R940 Back Panel Replacement: adım 4, 2 resimden 1. Toshiba TECRA R940 Back Panel Replacement: adım 4, 2 resimden 2.
    • Remove the 11 mm screw from the right side of the hard drive access panel using a Phillips #0 screwdriver.
    • Remove the 3.5 mm screw from the left side of the access panel using a Phillips #0 screwdriver.
    • Use a plastic opening tool to pry off the access panel from the bottom.
  5. Toshiba TECRA R940 Back Panel Replacement: adım 5, 1 resimden 1.
    • Remove twelve 5.5 mm screws from the main back cover using a Phillips #0 screwdriver.
    • Remove three 11 mm screws from main back cover and mini access panel using a Phillips #0 screwdriver.
    • Remove two 9.5 mm screws from the main back cover using a Phillips #0 screwdriver.
  6. Toshiba TECRA R940 Back Panel Replacement: adım 6, 2 resimden 1. Toshiba TECRA R940 Back Panel Replacement: adım 6, 2 resimden 2.
    • Lift the hard drive out of the access panel.
    • Disconnect the SATA connector from the hard drive by pulling straight out.
  7. Toshiba TECRA R940 Back Panel Replacement: adım 7, 2 resimden 1. Toshiba TECRA R940 Back Panel Replacement: adım 7, 2 resimden 2.
    • Insert the plastic opening tool into the edge of the laptop and pry off the back cover.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 28
Her zaman: 1,052
