Giriş
The hard drive is one of the most simple part replacements to perform on this computer. A screwdriver and prying tool are the only tools needed.
Neye ihtiyacın var
Loosen the screw holding the back panel for RAM in place using a Phillips #0 screwdriver. Once loosened, lift the panel up and set it aside.
Bir Yorum
I cannot lift up the “back cover” (step 1). I’ve twirled the screw left for minutes and tried to lift up the panel using a small flathead screwdriver and it will not lift up. HELP!
