Giriş
The optical drive is a relatively simple replacement. It must also be removed to access the keyboard.
Neye ihtiyacın var
Unscrew the single screw on the RAM access panel using a Phillips #0 screwdriver.
Use a plastic opening tool to pry off the access panel.
Remove two 2.5 mm screws from the side of the optical drive using a Phillips #0 screwdriver.
Neredeyse bitti!
Sonuç
