Ana içeriğe geç
Toshiba TY-LP 200 Belt Replacement
Neye ihtiyacın var
  1. Toshiba TY-LP 200 Belt Replacement, Belt: adım 1, 2 resimden 1. Toshiba TY-LP 200 Belt Replacement, Belt: adım 1, 2 resimden 2.
    • Unplug the turntable and remove the dust cover by lifting the lid horizontally.
  2. Toshiba TY-LP 200 Belt Replacement: adım 2, 2 resimden 1. Toshiba TY-LP 200 Belt Replacement: adım 2, 2 resimden 2.
    • Locate the C-clip at the center base of the platter and remove it with a flathead screwdriver.
  3. Toshiba TY-LP 200 Belt Replacement: adım 3, 2 resimden 1. Toshiba TY-LP 200 Belt Replacement: adım 3, 2 resimden 2.
    • Once removed, very gently lift the platter straight up and off the device.
    • Flip the platter upside down.
  4. Toshiba TY-LP 200 Belt Replacement: adım 4, 3 resimden 1. Toshiba TY-LP 200 Belt Replacement: adım 4, 3 resimden 2. Toshiba TY-LP 200 Belt Replacement: adım 4, 3 resimden 3.
    • Place the new belt around the center ring of the upside-down platter.
    • After placing the new belt, stretch the belt towards one of the indented areas on the back of the platter.
  5. Toshiba TY-LP 200 Belt Replacement: adım 5, 1 resimden 1.
    • Locate the spool drive that is surrounded by three screws.
  6. Toshiba TY-LP 200 Belt Replacement: adım 6, 1 resimden 1.
    • Once you have located the spool drive, place the stretched belt over it, and gently put back the platter into its original form, as shown in step 2.
    • If this step is done correctly, once the platter is spun, it will stop by itself.
  7. Toshiba TY-LP 200 Belt Replacement: adım 7, 2 resimden 1. Toshiba TY-LP 200 Belt Replacement: adım 7, 2 resimden 2.
    • Place the C-type back into its original place and, with your finger, attach it onto the spindle.
    • Reinstall the dust cover by placing it on the snaps and applying force downwards.
Sonuç
You now have a fixed and working record player.
Andrew
145 İtibar
1 Kılavuz yazıldı
3 Yorum
Thank you so much for this! Incredibly helpful!!!
Judi Dell'Anno - Yanıt
Replacement belt size?
lyam_pa - Yanıt
Along with this fix, I tried to clean a bit of dust and grime that's accumulated throughout the 3 decades. Some is not coming off with vacuuming or dry-wiping. Any advice on how to clean the unit up before reassembly? Mine is a gold Marantz with similar design and some of its parts are not as smooth as they should be. Thanks so much
Edie K - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 15
Her zaman: 1,368
