Ana içeriğe geç
Toshiba Tecra 8200 Hard Drive Replacement
Neye ihtiyacın var
  1. Toshiba Tecra 8200 Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off the device and unplug the power cord.
    • To remove the battery, flip the device, so that the bottom is facing upward.
  2. Toshiba Tecra 8200 Hard Drive Replacement: adım 2, 3 resimden 1. Toshiba Tecra 8200 Hard Drive Replacement: adım 2, 3 resimden 2. Toshiba Tecra 8200 Hard Drive Replacement: adım 2, 3 resimden 3.
    • Slide the battery to the right side until you hear a click.
    • Carefully remove the battery from its compartment.
  3. Toshiba Tecra 8200 Hard Drive Replacement, Hard Drive: adım 3, 3 resimden 1. Toshiba Tecra 8200 Hard Drive Replacement, Hard Drive: adım 3, 3 resimden 2. Toshiba Tecra 8200 Hard Drive Replacement, Hard Drive: adım 3, 3 resimden 3.
    • Locate the hard drive panel.
    • Remove the single screw labeled F4 by using a Philips size #00 screwdriver.
    • Save the screw, as it will be needed for reassembly.
    • Remove the panel, exposing the hard drive.
  4. Toshiba Tecra 8200 Hard Drive Replacement: adım 4, 2 resimden 1. Toshiba Tecra 8200 Hard Drive Replacement: adım 4, 2 resimden 2.
    • Pull the tab to remove the hard drive.
    • Insert the new hard drive by pushing it into the compartment, leaving the new "pull" tab exposed.
  5. Toshiba Tecra 8200 Hard Drive Replacement: adım 5, 2 resimden 1. Toshiba Tecra 8200 Hard Drive Replacement: adım 5, 2 resimden 2.
    • Tuck the "pull" tab back into the hard drive compartment.
    • Replace the panel.
    • Replace the single F4 screw.
  6. Toshiba Tecra 8200 Hard Drive Replacement: adım 6, 3 resimden 1. Toshiba Tecra 8200 Hard Drive Replacement: adım 6, 3 resimden 2. Toshiba Tecra 8200 Hard Drive Replacement: adım 6, 3 resimden 3.
    • Identify the connector pins on the battery.
    • Line up the connector pins on the battery with the connector pins on the computer and push inward to reconnect the battery.
    • Slide the exterior panel towards the center of the computer to lock the battery in place.
Bitiş Çizgisi
Sally
306 İtibar
3 adet Kılavuz yazıldı
Ekip
Ohio State, Team 1-3, Buehl Winter 2015 Ohio State, Team 1-3, Buehl Winter 2015 üyesi
OSU-BUEHL-W15S1G3
3 Üyeler
9 adet Kılavuz yazıldı
Bir Yorum
Awesome Thanks!
Erin Dulac - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 2,219
