Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
To remove the battery, flip the device, so that the bottom is facing upward.
Slide the battery to the right side until you hear a click.
Carefully remove the battery from its compartment.
Position device so the screen is face down.
Locate RAM Panel.
Remove two Phillips #00 screws labeled F4.
Remove panel.
Pinch clips on each side of RAM chips to release.
Gently remove RAM chips at a 45 degree angle. Use a plastic opening tool if RAM chips do not pop open.
