Ana içeriğe geç
Toshiba Tecra Z50-A Speakers Replacement
Neye ihtiyacın var
  1. Toshiba Tecra Z50-A Speakers Replacement, Back Panel: adım 1, 1 resimden 1.
    • Turn off the laptop.
    • Flip the laptop over so the bottom is facing upwards and the hinges are closest to you.
    • Remove the fifteen 5 mm screws from the back panel using a Phillips #0 screwdriver.
  2. Toshiba Tecra Z50-A Speakers Replacement: adım 2, 1 resimden 1.
    • Lift up back panel using your hands and remove it from the rest of the laptop.
  3. Toshiba Tecra Z50-A Speakers Replacement, Battery: adım 3, 1 resimden 1.
    • Lift the plastic covering over the battery plug.
  4. Toshiba Tecra Z50-A Speakers Replacement: adım 4, 1 resimden 1.
    • Pull the wired cable up towards the top of the laptop to disconnect it from its socket on the motherboard.
  5. Toshiba Tecra Z50-A Speakers Replacement: adım 5, 1 resimden 1.
    • Remove the single 2 mm screw from the corner of the laptop using a Phillips #0 screwdriver.
  6. Toshiba Tecra Z50-A Speakers Replacement: adım 6, 1 resimden 1.
    • Remove the three 3 mm screws from the battery using a Phillips #0 screwdriver.
  7. Toshiba Tecra Z50-A Speakers Replacement: adım 7, 1 resimden 1.
    • Lift up on the battery with your hands and remove it from the laptop.
  8. Toshiba Tecra Z50-A Speakers Replacement, Hard Drive: adım 8, 1 resimden 1.
    • Lift up on the hard drive.
  9. Toshiba Tecra Z50-A Speakers Replacement: adım 9, 2 resimden 1. Toshiba Tecra Z50-A Speakers Replacement: adım 9, 2 resimden 2.
    • Pull out the plug from the hard drive.
  10. Toshiba Tecra Z50-A Speakers Replacement, Speakers: adım 10, 1 resimden 1.
    • Lift up on the tape holding the bundled speaker wire down.
  11. Toshiba Tecra Z50-A Speakers Replacement: adım 11, 1 resimden 1.
    • Pull the bundled wire out of its socket on the motherboard.
  12. Toshiba Tecra Z50-A Speakers Replacement: adım 12, 3 resimden 1. Toshiba Tecra Z50-A Speakers Replacement: adım 12, 3 resimden 2. Toshiba Tecra Z50-A Speakers Replacement: adım 12, 3 resimden 3.
    • Lift up on the left speaker with a spudger.
  13. Toshiba Tecra Z50-A Speakers Replacement: adım 13, 3 resimden 1. Toshiba Tecra Z50-A Speakers Replacement: adım 13, 3 resimden 2. Toshiba Tecra Z50-A Speakers Replacement: adım 13, 3 resimden 3.
    • Lift up on the right speaker with a spudger and remove both speakers from the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Luis Juen Baez
585 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-4, Sinclaire Fall 2021 UMass Dartmouth, Team 2-4, Sinclaire Fall 2021 üyesi
UMASSD-SINCLAIRE-F21S2G4
3 Üyeler
21 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 27
Her zaman: 338
