Ana içeriğe geç
Toshiba Thrive Battery Replacement
  1. Toshiba Thrive Battery Replacement, Back Cover: adım 1, 1 resimden 1.
    • Make sure the lock switch for the back cover is unlocked.
    • The cover is unlocked when the switch is slid in the direction of the 'unlock' icon.
    FixBot'a Sor
    Yorum Ekle
  2. Toshiba Thrive Battery Replacement: adım 2, 2 resimden 1. Toshiba Thrive Battery Replacement: adım 2, 2 resimden 2.
    • Remove back cover by prying away from the Thrive.
    • The easiest place to pry from is one of the two speakers.
    FixBot'a Sor
    Yorum Ekle
  3. Toshiba Thrive Battery Replacement: adım 3, 1 resimden 1.
    • To remove the battery, make sure the lock switch is in the unlocked position.
    • The battery is unlocked when the switch is slid to the unlocked position.
    FixBot'a Sor
    Yorum Ekle
  4. Toshiba Thrive Battery Replacement: adım 4, 3 resimden 1. Toshiba Thrive Battery Replacement: adım 4, 3 resimden 2. Toshiba Thrive Battery Replacement: adım 4, 3 resimden 3.
    • Slide the battery switch release to the right.
    • While holding the switch in place, lift up the battery.
    FixBot'a Sor
    Yorum Ekle
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Kason
1.120 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 10-1, Brown Fall 2014 USF Tampa, Team 10-1, Brown Fall 2014 üyesi
USFT-BROWN-F14S10G1
3 Üyeler
12 adet Kılavuz yazıldı
1Rehber Yorum
You should give links on where we can buy the parts that need to be replaced.
Meggie Guerrer - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 27
Her zaman: 2,647
