Ana içeriğe geç
Toshiba Thrive Midframe Replacement
Neye ihtiyacın var
  1. Toshiba Thrive Midframe Replacement, Back Cover: adım 1, 1 resimden 1.
    • Make sure the lock switch for the back cover is unlocked.
    • The cover is unlocked when the switch is slid in the direction of the 'unlock' icon.
  2. Toshiba Thrive Midframe Replacement: adım 2, 2 resimden 1. Toshiba Thrive Midframe Replacement: adım 2, 2 resimden 2.
    • Remove back cover by prying away from the Thrive.
    • The easiest place to pry from is one of the two speakers.
  3. Toshiba Thrive Midframe Replacement: adım 3, 1 resimden 1.
    • To remove the battery, make sure the lock switch is in the unlocked position.
    • The battery is unlocked when the switch is slid to the unlocked position.
  4. Toshiba Thrive Midframe Replacement: adım 4, 3 resimden 1. Toshiba Thrive Midframe Replacement: adım 4, 3 resimden 2. Toshiba Thrive Midframe Replacement: adım 4, 3 resimden 3.
    • Slide the battery switch release to the right.
    • While holding the switch in place, lift up the battery.
  5. Toshiba Thrive Midframe Replacement, Midframe: adım 5, 2 resimden 1. Toshiba Thrive Midframe Replacement, Midframe: adım 5, 2 resimden 2.
    • Start by using a screwdriver to remove the 12 screws holding on the back cover. The screws are 5mm in length and require a PH0 screwdriver.
    • All of these screws are identical so don't worry about getting them mixed up.
  6. Toshiba Thrive Midframe Replacement: adım 6, 3 resimden 1. Toshiba Thrive Midframe Replacement: adım 6, 3 resimden 2. Toshiba Thrive Midframe Replacement: adım 6, 3 resimden 3.
    • Start to gently pry the back of the device off, while leaving it loosely in place.
    • Be careful not to tear or damage the cables when removing the back.
  7. Toshiba Thrive Midframe Replacement: adım 7, 3 resimden 1. Toshiba Thrive Midframe Replacement: adım 7, 3 resimden 2. Toshiba Thrive Midframe Replacement: adım 7, 3 resimden 3.
    • Once the back of the case is off, disconnect the wires by gently pulling on the plastic tabs as shown.
  8. Toshiba Thrive Midframe Replacement: adım 8, 2 resimden 1. Toshiba Thrive Midframe Replacement: adım 8, 2 resimden 2.
    • Carefully open the device like a book and lay the two halves beside each other.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Kason
1.120 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 10-1, Brown Fall 2014 USF Tampa, Team 10-1, Brown Fall 2014 üyesi
USFT-BROWN-F14S10G1
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 5
Her zaman: 360
