Ana içeriğe geç
Toshiba Thrive Screen Replacement
Neye ihtiyacın var
  1. Toshiba Thrive Screen Replacement, Back Cover: adım 1, 1 resimden 1.
    • Make sure the lock switch for the back cover is unlocked.
    • The cover is unlocked when the switch is slid in the direction of the 'unlock' icon.
    FixBot'a Sor
    Yorum Ekle
  2. Toshiba Thrive Screen Replacement: adım 2, 2 resimden 1. Toshiba Thrive Screen Replacement: adım 2, 2 resimden 2.
    • Remove back cover by prying away from the Thrive.
    • The easiest place to pry from is one of the two speakers.
    FixBot'a Sor
    Yorum Ekle
  3. Toshiba Thrive Screen Replacement: adım 3, 1 resimden 1.
    • To remove the battery, make sure the lock switch is in the unlocked position.
    • The battery is unlocked when the switch is slid to the unlocked position.
    FixBot'a Sor
    Yorum Ekle
  4. Toshiba Thrive Screen Replacement: adım 4, 3 resimden 1. Toshiba Thrive Screen Replacement: adım 4, 3 resimden 2. Toshiba Thrive Screen Replacement: adım 4, 3 resimden 3.
    • Slide the battery switch release to the right.
    • While holding the switch in place, lift up the battery.
    FixBot'a Sor
    Yorum Ekle
  5. Toshiba Thrive Screen Replacement, Midframe: adım 5, 2 resimden 1. Toshiba Thrive Screen Replacement, Midframe: adım 5, 2 resimden 2.
    • Start by using a screwdriver to remove the 12 screws holding on the back cover. The screws are 5mm in length and require a PH0 screwdriver.
    • All of these screws are identical so don't worry about getting them mixed up.
    FixBot'a Sor
    Yorum Ekle
  6. Toshiba Thrive Screen Replacement: adım 6, 3 resimden 1. Toshiba Thrive Screen Replacement: adım 6, 3 resimden 2. Toshiba Thrive Screen Replacement: adım 6, 3 resimden 3.
    • Start to gently pry the back of the device off, while leaving it loosely in place.
    • Be careful not to tear or damage the cables when removing the back.
    FixBot'a Sor
    Yorum Ekle
  7. Toshiba Thrive Screen Replacement: adım 7, 3 resimden 1. Toshiba Thrive Screen Replacement: adım 7, 3 resimden 2. Toshiba Thrive Screen Replacement: adım 7, 3 resimden 3.
    • Once the back of the case is off, disconnect the wires by gently pulling on the plastic tabs as shown.
    FixBot'a Sor
    Yorum Ekle
  8. Toshiba Thrive Screen Replacement: adım 8, 2 resimden 1. Toshiba Thrive Screen Replacement: adım 8, 2 resimden 2.
    • Carefully open the device like a book and lay the two halves beside each other.
    FixBot'a Sor
    Yorum Ekle
  9. Toshiba Thrive Screen Replacement, Front Camera: adım 9, 2 resimden 1. Toshiba Thrive Screen Replacement, Front Camera: adım 9, 2 resimden 2.
    • Separate the two halves of your Thrive
    • Using a Phillips screwdriver, remove the six screws holding the LCD in place. These screws are 3mm in length and require a PH0 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  10. Toshiba Thrive Screen Replacement: adım 10, 1 resimden 1.
    • With a spudger, disconnect the cable connecting the camera to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  11. Toshiba Thrive Screen Replacement: adım 11, 2 resimden 1. Toshiba Thrive Screen Replacement: adım 11, 2 resimden 2.
    • Lift up the LCD from the screen and place it on the side
    FixBot'a Sor
    Yorum Ekle
  12. Toshiba Thrive Screen Replacement: adım 12, 2 resimden 1. Toshiba Thrive Screen Replacement: adım 12, 2 resimden 2.
    • Remove the one screw holding the camera in place. The screw is 3mm in length and requires a PH0 screwdriver.
    • Lift up the camera from the screen.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Kason
1.120 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 10-1, Brown Fall 2014 USF Tampa, Team 10-1, Brown Fall 2014 üyesi
USFT-BROWN-F14S10G1
3 Üyeler
12 adet Kılavuz yazıldı
1Rehber Yorum
Indicate which tools are needed at the top of each guide.
Dan Brown - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 29
Her zaman: 1,968
